My RPM gauge won't work. Please help!
Discussion in 'Experienced Truckers' Advice' started by Dave2014, Mar 7, 2015.
  1. Dave2014
    Dave2014 Bobtail Member
    24
    Jan 20, 2014
    Hello! I have a '07 Volvo cummins engine. Earlier today the light for check climate unit light kept turning on but now my rpm gauge won't work at all. I am currently on a load. Is it alright if I continue to keep going? Is there any negative side effects on traveling with a broken rpm?
    Please and thank you to anyone who has any advice.
    -Dave
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    As long as the speedo works you should be able to continue to someplace to get it checked out. Since most gauges are now electronic, I would get it checked as soon as possible. It might be the precursor to a larger problem that could leave you stranded.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    ...and it's called a tachometer.
    Dave2014, x#1 and 201 Thank this.
  5. Dave2014
    24
    Jan 20, 2014
    But would this have negative effect on my motor until I reach my destination?
    Thank you so much for your reply!
  6. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    No it wont have any negative effect on your engine. It is just a gauge that tell you what RPM's your engine is running. I guess the only negative effect will be for you to see when you are going to shift your transmission. Just don't over rev your engine and you'll be fine.
    Dave2014 Thanks this.
  7. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Are you saying after 5 yrs, you have no idea if you're doing 1500 rpm or... 4500 rpm by engine sound?
  8. coueshunter
    coueshunter Heavy Load Member
    728
    432
    Nov 23, 2014
    Hell, if your this paranoid about no tachometer... I'm not sure you can shift with out it
    JolliRoger Thanks this.
  9. Ukumfe
    Ukumfe Medium Load Member
    301
    515
    Oct 23, 2008
    He is saying that, and so much more...... :biggrin_25511:
  10. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    errr my gawd....my head...
    MJ1657 Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    yes, it could have a negative impact if not fixed. and i say COULD.
    your ecm needs to know what cylinders to fire at what time. it does that by using a crank angle sensor and a cam sensor. and i beleive, the tachometer also works off the cam sensor. at some point and time. the truck may stop running. if the tachometer works off the same one of the sensors. and that particular sensor completely fails.
    so i say, COULD have an impact.
    i drove a 99 pete with a cat that failed tachometer. 2 months later it quit running. but you have a cummins motor. you may not end up with the same problem. you might have 2 seperate sensors. or it may just be a completely different problem not related to the sensors.
