My DPF light just stays on..
Discussion in 'International Forum' started by 2013Maxx, Apr 30, 2020.
  1. 2013Maxx
    2013Maxx Light Load Member
    135
    42
    Jan 17, 2018
    I have an issue with my 2013 ProStar with the Maxx13 all of a sudden.. It has good power and all but my DPF light just stays on.. Its not asking for a parked regen or anything.. The light is just simply on.. Have you ever seen this before? Or know what the issue could be? Thanks..
  3. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    How many miles on the engine? When was the last time you had the DPF filter and the after treatment system cleaned and serviced?
  4. 2013Maxx
    135
    42
    Jan 17, 2018
    455k and I’ve never had it cleaned.. Bought the truck with 177k
  5. 2013Maxx
    135
    42
    Jan 17, 2018
    So I finally made it to my destination 200 miles away from home and I just pressed the regen switch to see what it would do and sure enough it’s regenerating, but the exhaust doesn’t seem to get as hot as it usually does.. It’s just strange that it the light stood on for about 150miles.. Usually it’ll go away after 5-10 miles if it ever even comes on.. It regenerated for 10min and now it’s back to normal.. Just weird..
  6. Eddiec
    2,191
    3,358
    Feb 2, 2015
  7. 2013Maxx
    135
    42
    Jan 17, 2018
  8. AModelCat
    154,238
    White smoke during regen? White smoke usually indicates DOC is worn. If the exhaust temperature is indeed low, a failing DOC would be suspect.
    QUALITYTRUCK Thanks this.
  9. 2013Maxx
    135
    42
    Jan 17, 2018
    Yes I saw white smoke/ash coming out.. Can I just clean the DOC and be ok?
  10. AModelCat
    154,238
    DOC is the heavy truck version of a catalytic converter. It doesn't collect particulates. Its a catalyst that reacts with diesel fuel to generate heat to regenerate the DPF. If its worn out and breaking down it should be replaced.
    2013Maxx and QUALITYTRUCK Thank this.
  11. Eddiec
    2,191
    3,358
    Feb 2, 2015
    2013Maxx Thanks this.
