Mx 13 egr valve
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Oct 4, 2018.
  1. insanityeight
    insanityeight Light Load Member
    287
    111
    Jul 26, 2013
    birmingham al
    can you unplug or trick egr valve to stay closed on mx 13? They guys that programmed mine obviously didnt and my oil is getting black 1000 miles after oil change.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Weld Venturi tube shut?
  4. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    1000 miles? this is normal, if you "increase" and maintain your service frequency, you can bring it back to more of an iridescent black as opposed to a sooty black. This is the color of engine oil. This can only be good for any motor.
    insanityeight Thanks this.
  5. insanityeight
    287
    111
    Jul 26, 2013
    birmingham al
    No its not normal. My last delete would run close to 8000 miles before oil started turning from gold to black
  6. JohnC123
    135
    66
    Jan 25, 2018
    Wow, clean engine! sorry I responded.
  7. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    What was last engine?
    Here is what I know. If you unhook the rod connecting the valve to the controller the ecm will derate you 20%. And they will not recalibrate the egr. Only replace the whole thing.
    And it's all the same turbo, and egr as an isx.
    You need a good mechanic to also go into and tune the ecm. If they cant or won't they are a hack job.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Well your half right. Turbo is Holset on both. EGR is nothing alike.
    pushbroom, Oldironfan and spsauerland Thank this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I’ve never owned a Diesel engine that didn’t turn the oil black in short order.
