Must have tools
Discussion in 'Questions From New Drivers' started by Art08, Feb 22, 2018.
  1. Art08
    Art08 Bobtail Member
    23
    6
    Nov 21, 2017
    I am a new driver. I got Volvo truck from my OO with no tools in it at all. I know that is not my responsibility to take care of the problems but I would like to start setting up my toolbox with “must have” tools even if it is gonna be a starting kit. Asking for advices what these tools should be - name of the tools and sizes. Thank you.
    Lepton1 Thanks this.
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,762
    Mar 9, 2014
    In a van down by the River.
    A bsaic wrench set. I'm not sure if Volvo is standard or metric, but some one else can answer that. Wire strippers, electrical tape, wire connectors. I also carried a 2.5 lb sledge hammer. Wire cutters. Needle nose pliars. A small knife of some sorts. Flashlight. Head lamp for hands free working at night. Phillips and flathead screwdrivers.
    My most absolute important tool was my multiman tool. Had the knife and other things in it. Gerber makes a good one.
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    When I was a company driver I carried all kinds of crap in the side compartments . All kinds of tools and if they had any spare parts in the shop I took them. belts tensioners,fittings, hoses I didnt care lol and I had just about every tool to do any job. Including swapping a turbo on the shoulder of i80 with another Driver lol. But I also saved them a lot of money over time. But, carrying tools isn’t about saving the company money. It’s about saving yourself the wasted time too. If you can fix something why not fix it and move on instead of flashers and triangles then wait for road service. Screw that
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Good question.
    Especially in winter you should always have a set of fuel filters AND a filter wrench AND a gallon blend of 70% diesel, 20% Howe's Antigel, and 10% Diesel 9-1-1. Also have large garbage bags.
    Now get on YouTube and watch videos teaching how to change fuel filters.
    How do you know when you need to change your fuel filters? It's when you start losing power when temperatures are well below freezing, you can't get above 1500 rpm's, the engine coughs and sputters when you apply more throttle, and your mpg readout starts showing sub 4 mpg on the flats.
    Usually you can change just the primary fuel filter and get back on the road. The reason why you are getting that power loss is because the engine is starved for fuel. Fuel can't get through the primary filter (the first fuel filter from the tanks) because water in the fuel starts freezing as soon as it hits the cold paper filter. Soon that paper filter is coated in ice and very little diesel can get through.
    I have had to change out fuel filters in the winter several times. After changing filters you get your power back and get normal mpg. Without having spare filters and a GOOD filter wrench you risk being shut down in sub zero temperatures and you may not even be able to idle your truck.
    That's a recipe for a full on survival situation.
  6. Landincoldfire
    Landincoldfire Heavy Load Member
    869
    4,639
    Sep 27, 2015
    New Holland, Pa
    If you're pulling dry van. Add a small crowbar for pulling nails out of the floor and maybe small bolt cutters for trailer seals.
    Rollr4872 and Lepton1 Thank this.
  7. Numb
    Numb Crusty Curmudgeon
    3,937
    8,743
    Jan 30, 2012
    Charlotte, N.Carolina
    vice grips.
    used to use them on those old trailers with the spring load pins.
    Pull the handle out ,clamp the vice grips on and move the trailer until the pins pop in.
    my company went all "air pull" pins.
    yeah, for the wore out shoulder sockets!!!!!!!!! lol
  8. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    Back in the old days most truckers carried a fully stocked toolbox. These days though most truckers just call the company if they have an issue and wait on a service truck. I think you should determine which type of trucker you will be. If you are never going to get too deep involved in repairs I suggest simple things. 1 a good broom. 2 a roll of duct tape. 3. a pair of some type of gripping tool like vise grip and/or channel lock. 4. a good flashlight. This serves 2 purposes if you get the right kind. Useful for your pre/post trips in the dark and for giving an idiot an attitude adjustment. 5 a good supply of bungee cords and straps. 6 a tire pressure gauge. 7 something to cut seals. Some of these seals need bolt cutters. These 7 items should be a starting point After this any other tool you need that is needed for your specific type of trucking.
    Edited to add this: While it is not a (tool) I also suggest a good pair of rubber boots. These are handy for those times when a trailer you need is parked in a mud hole and for those times when it is dark out and you are walking around trailers and there are piles of both human and animal excrement all over. (yes drivers will drop a deuce like this)
    Rollr4872, BUMBACLADWAR and Lepton1 Thank this.
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    A laptop with dealer specific diagnostic programming is the only way to tell you what causes your symptoms on modern trucks. And the only way to reset the check lights. I hate modern trucks.
    meechyaboy and Lepton1 Thank this.
  10. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
