Muncie PTO stuck
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Nov 30, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Noticed my air Muncie PTO is stuck on.(engaged) Is there a way I can dis-engage the pto so I can drive the truck to the mechanic which is about 50 min. away. Thanks.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    If you unhook line from pto is air coming from it with the switch off? If so plug it or bend it double and tie strap it.
  4. lwlevens
    623
    427
    Feb 9, 2018
    Didn't check that will tomorrow though. So if air is coming out of the line with the switch off what does that tell me?
  5. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    Switch is bad. The air piston in PTO is returned by a spring. I never saw one brake. Maybe the piston is stuck.
  6. lwlevens
    623
    427
    Feb 9, 2018
    Ok thanks brother,will check it tomorrow.
  7. lwlevens
    623
    427
    Feb 9, 2018
    So is there a way to dis-engage or disconnect the Pto so I can drive the truck to the mechanic?
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    What is attched to the PTO?
  9. lwlevens
    623
    427
    Feb 9, 2018
    Going to check the PTO out this morning. Now what if there is air going through the line with the pto switch off then what? Thanks,PTO is attached to the trans.
  10. dumptruck89
    dumptruck89 Light Load Member
    79
    105
    Feb 27, 2015
    MA
    Cap the air line with something and either bring it to the mechanic or go get a new switch and replace it. There pretty straight forward to swap out. If it's the same exact switch just put the lines in the same spot on the new one.
    AModelCat Thanks this.
  11. lwlevens
    623
    427
    Feb 9, 2018
    Well uncapped the air line going to the air solenoid on the pto,sprayed some wd40, tapped it a few times with a hammer and it works now hopefully it wont act up again.When in doubt smack it with a hammer.Thanks Guys.What is that part called anyway pto air solenoid?
