Mufflers
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, May 15, 2013.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    As most of you are aware, Kenworth factory mufflers the exhaust enters and exits on the same end of the muffler. Years ago I cut the the end of my mufflers off and gutted them, did see an increase in fuel mileage and throttle response afterwards. I ran it like that for a couple of years before I got rid of everything under there and went straight from the Y-pipe to the stacks, I did not notice any difference in fuel economy or throttle response/power from doing that. After I put the bullydog tune in my ecm I now have a drone that is driving me crazy from 1300-1500rpm. I put resonators behind my sheilds on my stacks and it helped some, but it is still there and I am sick of it. If I put my factory gutted mufflers back on with a tuned ecm do you think that there will be a negative impact on fuel mileage or power?
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Based on what u have said , no . I don't think u will have a negative impact , or maybe a very small one, but the peace and quite would be better I think.
  4. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    i forget the number of inches of back pressure, but the factory KW muffler is the worse. I've seen before and after dyno runs simply removing the muffler and its quite a difference. Get the Grand Rock M-922 and you'll love it. No too loud and no drone.
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    The side stacks on my previous truck, Intl 9400i, used a muffler underneath that was in and out the same end. I just took it off, had curved exhaust pipe made up, put on a 10" resonator, and problem solved. Nice "U" shape and good exhaust flow. Haven't seen the Grand Rock setup, but I know that Pitts Power has several high flow muffler with "U" shape pipe setups for direct plug and play on KW, Intl, etc.
    http://www.pittsburghpower.com/index.php?cPath=25_62&osCsid=5935b37010ded2e02a8678b138df87d8
  6. bgxpress2006
    bgxpress2006 Light Load Member
    248
    73
    May 25, 2013
    Montreal, Quebec
    Can someone tell me what Drone means, I have an 07 kw with a c15 ACERT AND I also want to remove thst restrictive system and was thinking of doing same thing by simply routing straight into a Y pipe and out side stacks, with a single resinator before the y pipe
  7. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    A drone is a Y pipe off of a 6 cylinder engine. Mainly for show. 2 stacks look nice. You can tell if one stack fires first. Cali started it first.
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Huh? :biggrin_2552:
    A drone a very annoying sound that echos through out the truck.
    intrepidor and Ruthless Thank this.
  9. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    Thats kinda of what I figured (sound) I just wanted to make sure
  10. Oscar the KW
    12,246
    28,114
    May 19, 2011
    And it typically only occurs at certain RPM's. On my acert it is from 1300-1450 rpm, right smack dab in the middle of my cruising RPM. A drone occurs when the exhaust reaches a certain pitch and resonates or vibrates thru the exhaust, sometimes it can be eliminated by using rubber isolaters between the mounting points of the exhaust and the vehicles frame. I never had a drone with my truck until I got a tune put in the ECM.
  11. hmtruk
    hmtruk Light Load Member
    123
    49
    Jun 7, 2009
    big lake ,mn
    try running a weed burner . don't like them but will take care of all your problems. know a lot of guys that run 8 to 10 stacks on there 379 and w 900 but run out of a weed burner stack for looks plus when you run exhaust out the bottom stacks stay looking like new.
