Mud flap question...is legal?
Discussion in 'Experienced Truckers' Advice' started by FatDaddy, Aug 20, 2012.
  1. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    Picked up a preloaded trailer in Sikeston, MO headed to New Brunfels TX. On my pretrip noticed the mudflap bracket was all bent to hell and somebody removed the mudflap and zip tied it in the back from the ICC bumper. Took it over to the TA in Matthews and they can't fix it unless they put the heat gun to it. Company said no as policy is no heat allowed to be applied to a loaded trailer. Road service assured me as long as the mud flap is hanging at proper height (it is) that although DOT doesn't like it...I am legal. I did get that in writing from them so I covered myself but I just wanted to see if anybody knows if this is really the case.
  3. mhawki12
    mhawki12 Bobtail Member
    45
    8
    Aug 20, 2012
    Hillsborough, Fl
    I think its gonna be up to the inspecting officer, the only thing i see written is about the height.
    ill keep looking though
    this is from the Florida CDL Manual
    11.2.6 – Rear of Vehicle
    Splash Guards
    • If equipped, check that splash guards or mud
    flaps are not damaged and are mounted
    securely.
    http://www.trailermanufacturersassociation.org/currentissues/currentissues1.html
    about halfway down
    Fenders / Mud Flaps
    QUESTION:
    Are there any requirements about fenders coming down a certain length over the wheels ?
    ANSWER:
    There are no requirements for fender coverage. There is an SAE "mud flap" standard but this is specified on a state by state basis.
    QUESTION:
    Are there any Federal Requirements regarding mud flaps on trailers?
    ANSWER:
    There are no federal requirements (e.g. in 49 CFR 393); however, there is an SAE Recommended Practice, J682 "Rear Wheel Splash and Stone Throw Protection" from October 1984 that several states reference in this area. Basically J682 says that "mud flaps" are required if the ratio of the bottom of the trailer bed to the length from the bottom of the wheel to the end of the trailer is > 1:3. In other words, if the bottom of the frame, at the end of the trailer is, say, 25", then the center of the rear wheels must be more than 75" from the back of the trailer. If it is less than 75," then you need flaps of a length to restrict the ratio to the 1:3 number.
    Doesnt give any indication of of where they are mounted.
    FatDaddy Thanks this.
  4. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    You are probably good... BUT that thing you got in writing isn't worth the paper it is written on. If an officer wants to right you a ticket and has a question about it you are guilty until proven innocent.. I hope you make it as it seems your company won't let it be fixed properly
    aiwiron Thanks this.
  5. FatDaddy
    4,314
    10,375
    Dec 23, 2008
    Yeah I realize it always up to the officer, but I have it on the qualcolmn stating that policy is not to apply any heat to a loaded trailer and that once empty I can have it fixed properly. So I just hope this trip goes witout incident
  6. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    You'll be fine. just be honest if they ask ! and usually they will say get it fixed at next stop. Remember don't be smart to him just explain the situation !
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Just stay out of Arizona. That's the only place I've ever been given grief about a mudflap and it was just an excuse to do a level 3 roadside inspection.
  8. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
    Never know with dot,depends and how is the officer mood.
  9. WorldofTransportation
    702
    577
    Sep 20, 2009
    Your mother
    Don't go south of San Antonio without getting it fixed all the scales down there will be looking for anything. One of our drivers had one of those flimsy rubber mudflaps (the ones that last forever but flop around) they gave him a ticket made him weight it down with chains and wrote him a ticket.. I believe it was like 28 points on his csa for (and yes that was before the points start to work away)
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Arizona loves to write tickets for "sailing mudflap."
  11. FatDaddy
    4,314
    10,375
    Dec 23, 2008
    I will be bringing it straight to the TA in New Brunfels as soon as I am offloaded
