moving peterbilt mirrors from door to cab
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jk4229, Nov 12, 2011.
  1. jk4229
    jk4229 Bobtail Member
    13
    Feb 13, 2011
    humboldt,ia
    is there a kit to move your peterbilt mirrors off the door? getting readt to paint truck and was thinking this might be a good time. truck is a 2003 379 exhd
  3. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    You should be able to go to a wrecker and get the whole mirror assemblies from '05 - '07 379/378 and rivet/bolt them on. There is a casting that is riveted to the cab to hold the lower arm. This has a cover (SS, Alum, Chrome I don't recall). I would recommend buying the castings new rather than used as they have a tendency to fracture. Should be an easy conversion but likely won't be cheap. Before purchasing parts, examine a 05-07 to make sure that the cabs are identical but I can't see why they wouldn't be.
    Coolbreezin Thanks this.
  4. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I like mine attached to the door. This way I can open the door and look out the mirror at different angles instead of leaning halfway out the door.
    I have a '04, and our other drivers keep telling me they wish they had my mirrors.
  5. kelgar50
    kelgar50 Medium Load Member
    334
    218
    Feb 1, 2007
    Bakersfield,CA
    I have had pete's with the mirrors om the door and now have a 07 386 and I sure miss being able to use the door to move the mirror when backing.
  6. sicshovel
    sicshovel Light Load Member
    65
    8
    Sep 2, 2010
    Hager City Wi.
    Yes you can get all tge parts from peterbilt. $1500.09 for both sides
    volvodriver01 Thanks this.
  7. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    WOW!!! :biggrin_2559:
  8. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    They buy them from Volvo...
  9. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    why would a guy named "blind driver" care about mirrors anyway?:biggrin_25522::biggrin_2559:
    TURKER and 07-379Pete Thank this.
  10. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I just back up full throttle and stop when hear an air horn. That's how I know I'm not going to make it :biggrin_25520:
    Then I try again :biggrin_2559:
  11. DoubleHTrucking
    DoubleHTrucking Bobtail Member
    6
    Sep 23, 2018
    Has anyone ever put 387 mirrors on a 379 or 386 I’m thinking about doing it but just wanted to see if anyone has done it
