Moving from Ohio to Texas
Discussion in 'Oilfield Trucking Forum' started by 68bulldog, Dec 7, 2014.
  1. 68bulldog
    68bulldog Bobtail Member
    4
    Dec 7, 2014
    I'm a newbie to the site, so please forgive me if I did not post in the right spot. I have 15 years driving in my county & surrounding counties hauling feed, but I must complete schooling now to obtain my Ohio CDL. Once obtaining my CDL & sometime the beginning months of 2015, we will be moving to TX. Does anyone the law in Texas? Do I have to retake the test or do I just transfer them?
  3. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    Good Luck. Your going to need it. The oil field is a tough place.
    68bulldog Thanks this.
  4. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    No you don't need to take a test. Just show up at the local DPS in TX and they will do the transfer. I switched from FL to TX a few years ago so I know the drill.
    and if you are thinking about buying a house, just be aware that TX has pretty high property taxes.
    You maybe surprised how high they are.
    good luck.
  5. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    well you will not be driving in snow, expect to put in the max hours allowed for days and weeks on end,,,if you want a 9 to 5 job then expect to make low wages,,,if you are willing to work what ever hours they want for weeks at a time you will make double or more that a steering wheel holder makes,,You get of of life what you put in to it,, Work till you drop and the rewards will be good ,,work like a sissy and you will not make it,,
  6. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    you should be able to find a job in Ohio...doing the same thing. (im just saying)
  7. newguy76
    newguy76 Light Load Member
    104
    31
    Aug 14, 2013
    Del Rio, TX
    Only test you would have to retake would be hazmat if you were to get that endorsement. If you want hazmat, just wait till you get to Texas
  8. unloader
    unloader Road Train Member
    1,037
    1,153
    Jan 7, 2013
    They will transfer without retesting, however hazmat doesn't transfer and will require a test and background check.
    Also be aware that you will need to register your personal vehicle in Texas before they will let you switch your license over. Hope that helps.
    unloader
  9. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    There's plenty to do in Ohio. Why move all the way to TX?
  10. buzzarddriver
    3,507
    10,020
    Feb 1, 2011
    Dallas, TX
    While Texas may have a higher(by percentage) property tax rate, the actual tax is lower by the fact that the property has a lower cost value. Also, NO state income tax and a median sales tax rate make Texas attractive to property owners.
    Now as to being able to find lodging in the oil patch. Supply vs demand has always caused an increase in prices, so you have to figure that in. But the lower oil prices will start to weed out the unprofitable fields which means fewer driving jobs available.
  11. Arky
    Arky Heavy Load Member
    853
    586
    Jun 7, 2013
    Yep...which lowers the denmand for CDL drivers. So, factor that in. Also factor in drivers moving into your area to take those jobs after the area that they were in dries up.
    77fib77 and 68bulldog Thank this.
