Hello I recently went to a fixed fith wheel plate on my truck...I mounted it too far forward and so when I'm loaded I'm about 1000 lbs. Heavy on my steers. I need to move it back and I'm wondering if anyone knows approximately how far I need to move it to move 1000 lbs. Back to my drives? I would like to know how many inches since I don't have a slider so notches don't tell me anyting. Thanx!
Moving fifth wheel plate
Discussion in 'Ask An Owner Operator' started by Dwight Goertzen, Feb 13, 2024.
I always had mine set just ahead of the mid point between the axles. YMMV.
Flat Earth Trucker, 86scotty and Numb Thank this. -
On a fixed plate position it with the pivot pins dead center of the tandems. If single axle put it about 4” forward of axle. This should be a good weight distribution in most applications.
86scotty Thanks this. -
I’m roughly a foot ahead of center and I’m 11,700 loaded. That’s with a set back axle and 250” wheelbase.
Oxbow and Diesel Dave Thank this. -
Its all going to depend on your wheelbase as to how much you'll need to adjust it.
Keep in consideration that not all kingpin depths are equal so you don’t want to put it permanently to far forward of tandem center and not be able to hook a trailer that may have a deep pin. Landing gear arn’t always back bumper friendly either so clearance may need to be made for them on some trailers. Back in the day sliding fifth wheels had more to do with being able to hook and pull different trailers with various pin depths than it did to get weight on or off the steers. Back than you wanted steers light anyway due to manual steering and no brakes.
Oxbow, Bean Jr. and Arctic_fox Thank this. -
Ok so my wheel base if I remember is 250 and a setback axle...pulling hopper bottom hauling bulk commodities.
Oxbow Thanks this. -
Oxbow, Diesel Dave and kylefitzy Thank this.
Ok thanx for the help!
