Moving cascadia switches
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DDFLD, Nov 19, 2015.
  1. DDFLD
    DDFLD Bobtail Member
    38
    13
    Aug 10, 2014
    Waterford, OH
    Currently in a 2015 cascadia. I was wondering is it is possible to move the dash switches around since from my understanding that each switch has an ID for the computer. If so does anyone know the process of removing them, individual switch, no the whole 4 gang cluster? Thanks.
  3. TonyPDX
    TonyPDX Bobtail Member
    4
    Yes you can move them.
    Pull the end caps out about 1/4" of an inch and the whole switch module will come out of the dash, then you can remove the individual switches buy pressing in the little tabs on the top and bottom of the switches and pull them out. To reinstall the switches just push the switches back in until you hear a click. Before putting the switch module back into the dash push the end caps back in so they are flush with the switch faces.
