Can someone suggest best way to fabricate bracket of some kind .
When my truck was painted , they connected both sides with welded 1x1 tubing , cracked once at the weld , weeks later cracked on the other side , ...removed tubing and made different bracket from angled iron by different shop who does only welding ...week later cracked ( not at the welding thought ) ....
I regret not getting special bracket for my suspension type ( trying to fix the way it is without ordering it and redrilling fenders )
Mounting half fenders
Discussion in 'Ask An Owner Operator' started by pavrom, Jul 19, 2021.
Page 1 of 4
Rideandrepair Thanks this. -
I would weld a metal triangle where the horizontal piece and the vertical piece meet. Weld it on the front side to help support that stressed point. I can't tell how much room you have but you'll want to keep the brake chamber accessible.
pavrom Thanks this. -
That angle iron cross brace looks like a good idea but should be higher so it’s inline with bracket. The way it is now it puts stress on the area where it hangs below bracket . Least that’s what it seems judging by pictures.
Magoo1968 Thanks this.
What brand are the fenders PAV?
I don’t know if anything is going to work. Your frame rails flex and move independently of each other. You could try welding triangle braces on, but I think they will crack the flat stock either up higher or crack the angle iron.
I would add two triangular gussets on either side of the cracked vertical to stop the flex from the weight of the fender hanging there and thicken the cracked vertical piece.
pavrom Thanks this.
Page 1 of 4
