Mounting beacon lights on your truck?
Discussion in 'Flatbed Trucking Forum' started by Shotgun94, Jan 15, 2019.
  1. Shotgun94
    Shotgun94 Medium Load Member
    446
    301
    Sep 24, 2017
    Georgia
    How did you do it? Any pictures?
  3. Espressolane
    16,967
    102,250
    Before you add beacons to your truck, you may want to check into the regulations for the states you will operate in. Some have mounting guidelines, a few, like Nevada, require permits. A few also have a cover when not in use requirement.
    These regulations may have changed some in the 6 or so years from when I had them on the truck.
    Diesel Dave Thanks this.
  4. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    Factory or dealership, I've been thinking about it on my truck and figure if I get a headache rack I'll mount them off that
    Shotgun94 Thanks this.
  5. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    91C38551-FD37-4ECA-9CAA-7D6A73B74ADE.jpeg 01360C24-C335-4E4D-BDEC-A0BFED3E1A43.jpeg EF55932C-49F7-4734-AE80-BC6E02348B68.jpeg E51E0978-9297-4CA2-B8F5-352BCEFB2999.jpeg Well if you want to control them from the cab, you can tap into the “work light” that most trucks have on the back. I recently tapped into that for back up led’s. I have my strobe on its own circuit with a switch.
    But basically if you tap into the work light, you already have power and ground there. Just got to drill some holes on the side of your fairings maybe, mount it, run the wires. I experimented on my back up led’s, used twist nuts to connects the three power and three grounds, then made a homemade junction box out of Tupperware, then silconed it up. Soldered all the other connections.
  6. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    I sure hope that jury-rigged mess happened as a quick solution on a cold day.
  7. HopeOverMope
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Well kind of. Every thing is soldered, dielectric grease and shrink wrapped! Lol ... except the three way
    I was trying to figure a way to solder the three way connection and still shrink wrap it. And I didn’t want butt connectors, so why not twist nut it, and isolate it from the weather! The twist nuts are “weatherproof” too.
    I guess I could of run two wires together and solder it into the other and still cover it with shinkwrap
    HoneyBadger67 and Shotgun94 Thank this.
  8. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    20171014_075534-01.jpeg 20180806_120410.jpg 20180806_120424.gif [​IMG]
    Tug Toy and Shotgun94 Thank this.
  9. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    i also have a light bar facing the rear. Can't find any pic of that
  10. Michael H
    Michael H Medium Load Member
    466
    1,023
    Nov 3, 2015
    Arizona
    Mounted on the sides of the fairings. Seperate dash switch.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    But I cheated I used the factory mounts......
    kylefitzy, Shotgun94 and PoleCrusher Thank this.
