MotorKote Stiction Remover
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fetch, Jan 6, 2014.
  1. fetch
    fetch Bobtail Member
    11
    Feb 27, 2013
    Manitoba
    Has anyone seen this product? Has anyone TRIED this product?
    The following is posted on their website. (Source http://motorkote.com/64oz-motorkote-stiction-remover.html )
    Injection Stiction occurs when oxidation & carbon build-up form inside the injector. This is related to newer injection technology that runs hotter & causes the oil side of the injector to stick or foul. MotorKote® Diesel Stiction Remover™ removes carbon build-up & provides a coating to eliminate friction in diesel injectors.
    BENEFITS:
    • Often Restores Fouled Injectors
    • Helps Restore Lost Power & Compression
    • Fights Deposit Build-up
    • Helps Reduce Friction Drag & Wear
    • Helps Prevent Build-up of Harmful Chemical Oxidation
    • Helps Reduce Noise & Vibrations in Lifters & Valves
    • Reduces Blow-by & Helps Smooth Idle
    RECOMMENDED USAGE:
    • Initial cleanup in Pickup Truck replace 64 fl oz of oil with Diesel Stiction Remover®
    • Prevention replace 32 fl oz of oil
    • Initial cleanup in Semi Truck replace 128 fl oz of oil with Diesel Stiction Remover®
    • Prevention replace 64 fl oz of oil
    I haven't found anyone talk about this product on forums, but when I start looking up other products of theirs, 80% seem to be bogus promotional posts from Chinese marketing firms (single post users with unsubstantiated claims), with 20% seeming to be from legitimate forum users (high post counts). I'd love to believe a witch doctor, but I'm not willing to spend what will be nearly $130 after taxes and shipping costs on snake oil. Just wanting thoughts or experiences.
    I always add Lucas or Howies to my fuel, but thought maybe trying this might offer additional help to improve performance.
  3. tator1960
    tator1960 Light Load Member
    68
    23
    Dec 29, 2013
    You are running Howes and you are worried about snake oil? Our local truck stop has started winter treating their fuel with Howes for the first time I'm having gel problems with their fuel.
    blacklabel Thanks this.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    UH, oh. you mentioned you used lucas. be ready.. you just made yourself a dart board on here. :yes2557: I have used it too. I used it for 14 years going over the 1.5 mil mark. I like it in the summer heat when oil can thin out. most on here do not see anything good about it, but they are civil in their opinion on it.
    “Doc” and EverLuc Thank this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ok, about bad pump injection units I see every day... not so many kinds of damage:
    1- bad nozzle, leaks fuel - black smoke
    2 bad valve and pump unit leaks fuel in return - no power, miss
    3. bad nozzle - exaust gas goes in return line - black, contaminated fuel, miss
    heavyhaulerss and EverLuc Thank this.
  6. fetch
    11
    Feb 27, 2013
    Manitoba
    (In reference to Lucas or Howes)
    Haha, I guess I'm a sucker! I bought a used truck last summer that I suspected hadn't been used/worked in about 4 years (just reading the paperwork in the truck). I decided that using additives to the fuel probably wouldn't hurt, but never really read about the true effect of the additives. Seeing those products being used constantly and finding them at my favorite independent stores helped sell me.
    I always wondered how effective Lucas Fuel Treatment was, when I tried to use it in winter, it would pour thicker than syrup.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I have used lucas fuel treatment. filled entire fuel filter(davco) with it. pored rest in the tanks. saw a difference in engine starting quicker & better m.p.g. if you use it fill primary filter with it & put rest is tanks at fill up.
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Is "stiction" even a scientific word that engineers use?
    "Oxidation" is rust. If the inside of your injectors are rusty nothing that comes in a bottle is gonna cure your ills.
    I use Lobos Fuel Stupifier, run three Turdolater 3000 fuel tubes in series to align my fuel particles and have Hurricane Air Vaporizer and I make so much money in fuel savings I travel to foreign countries and build cafeterias for the starving children.
  9. trees
    trees Road Train Member
    1,061
    833
    Jun 29, 2010
    I'm not sure about this stuff.....my gut tells me to leave it alone.....the people marketing it claim that it will keep your fuel injectors from gumming up and "sticking".... I guess the only thing I'm wondering is, how many snakes are in a bottle of this stuff???
  10. Jokingypsy
    Jokingypsy Medium Load Member
    669
    613
    Jan 4, 2013
    Are all those additives made by the same people that make those pills that will make my tally whacked bigger? I don't want to take a chance on getting a plugged up fuel injector.
    Dave_in_AZ Thanks this.
  11. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Hey hot shot secret is a sticktion remover .....wonder if sticktion is code word for money because the crap removes money from your wallet quite well
    JohnP3 Thanks this.
