Just purchased a new Monkey Made MM9 short shaft. My question is have they changed them or did I get a knockoff. My old MM9 only had 1 mast set screw plus a larger tube that the coil is welded to like the one pictured
Thanks Russ
Monkey Made
Discussion in 'CB Radio Forum' started by Crazyrider, Mar 11, 2020.
I haven't bought a MM in years, but builders often change things up a bit from year to year especially if they get enough complaints about a particular part failing, or maybe they just want to improve on the design. -
Bought mine in 2000-01 and it has two screws.
Had you bought a Predator 10K, I can guarantee those are still made one at a time in Burleson TX! -
Supposedly made in the USA. Had a Predator with the dual coils K-2-6sw. My old Monkey Made mm9 short shaft seemed to do a better job at receiving. Probably just opened a can of worms by saying that.
Is there a difference between a predator LiL Sweetie antenna and the k2 antenna
Kale told me a while back he was going to build some, and is selling quiet a few, but I haven't had a chance to get by his shop to get one to try out, so I have no idea how they perform...
Coil on the left is the lil sweetie, other one is a regular Predator 10K coil.
