monkey made or predator or wilson 2000?
Discussion in 'CB Radio Forum' started by lastgoodusername, Mar 19, 2012.
  1. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    will there be a noticeable improvement from a wilson 2000 to a monkey made or predator? running a general lee that has had some work done to it. thanks , johnny
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    IF they are about the same length they should work about the same
    lastgoodusername Thanks this.
  4. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    If I'm shelling out the bucks. I'm partial to the Predator. Never had any luck with Monkeymade. Haven't tried the Wilson.
  5. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    The Wilson is poorly constructed, likely to fall apart right at the base of the shaft. Never had a preditor, The Monkee-made tuned easily about a 6 1/2 " cut I believe . Performed well and very broadband. Found the owner did not want to honor his lifetime warranty regarding breakage when a tree removed it from mirror.
  6. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Dont forget Browning, they make a pretty good antenna too.
  7. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    :biggrin_2556: WHAT ?
    Then why spend big bucks for spyral arrays on space ships just put a monkeymade wip :biggrin_25513:
  8. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    Please explain ???
  9. 555 BigHorn Mobile
    555 BigHorn Mobile Bobtail Member
    29
    6
    Sep 23, 2011
    i copied and pasted that quote and im going to catch all kinds of flak for it
    but i will tell them where i seen it
    The Monkey Made antenna is a type of a circularization polarization - hence it would sound louder and clearer to someone else who was using the same antenna, and might sound quieter to someone who was not
    back to topic
    the predator 10k straight out the package with stinger stuck in will already recieve better than the wilson anything antennas
    and will gaurantee to work alot better than one of those flat coil browning things
    what a joke of a antenna
    as for the monkey made or stryker antennas
    any driver comes to me and asks about a Predator 10k
    i will tell him the 10k will outperform the monkeymade hands down
    if it dont then i give him the predator 10k
    and if it does then i give him a discount on the 10k but i keep the monkeymade and i have him roll over the monkeymade with his drive tires.
    and i put the 10k on and tune it the right way
    and send him on his way
    there are other antennas that i think are a tad better than the 10k but most drivers are not going to run them so i wont go anyfurther
    you can check me out here
    http://www.cbjunkies.com/forum.php?referrerid=40
    drop in and give me a pm to get you fixed up
  10. rollingradios
    rollingradios Light Load Member
    184
    66
    Mar 9, 2012
    Richmond, Va
    1. Predator double coil for trucks will outperform the Wilson 2k.
    2. Monkey made antennas are WAY too heavy and have only about 2" adjustment range vs 5-6" adjustment on the predator. Also the predator can use the same diameter whip as a wilson vs monkey takes a much larger and often hard to find replacement whip.
    3. There are situations where the short shaft wilson is the ONLY way to go if you are one who gets into a lot of tree limbs or other low clearance situations.
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    So what does all this have to do with a Monkey Made Antenna?
    Do you even know what a Monkey Made Antenna is or looks like?
    See....If you have had a Predator 10K, and a tree branch reached up out of no-where and snatched it off the mirror, all you would have to do is call the number on the shaft of the antenna, and whatever broke, a replacement part would be in the mail to you at "NO CHARGE"...
    I have seen guys who ran over their 10K's after they broke off, and flattened out the coil, and Kale would send them a new coil, and lower shaft at no charge...
    Regardless of how a 10K gets broke, it has a Life Time Warranty and replacement parts are only a phone call away...
