Does anyone know the model number for this transmission. Also, what is the final overdrive gear ratio and assuming I have properly geared rearends, say a 264 or 279 (whatever the numbers are) how fast can I go within reason?
Model number for 18 speed single overdrive trasmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by terrylamar, Mar 26, 2011.
Page 1 of 5
The single overdrives are the A ratio and the double overdrives are the B ratio. The final gear ratio is .86 in the A.
18 speeds are either 0.73 or 0.86 final drive
you can calculate road speed here
http://www.roadranger.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf -
missed your post 112...Last edited: Mar 26, 2011
264 0r 279 rears ????????????????
OK let's say you want 100 MPH.
100 MPH X .73 Tranny X 264 Rears X 1100 X 24.5 = 470 Rev per Mile
= 1510 RPMs.
100 X .73 X 279 X 470 = 1595 RPM's.
Now with .86 Final drive.
100 x .86 x 264 x 470 = 1067088000 = 1778 RPM's
100 x .86 x 279 x 470 = 1127718 / 60 = 1879.53 RPM's. -
I would have driveline on the ground in one day with those gears...t800kwopper Thanks this. -
OK, I'm missing something. I have looked at a list of Eaton Fuller 18 speeds, both ratios and I cannot find a single overdrive listing. Every model list the final ratio as .73.
Can you be more specific as to the model number? -
Uhhhhh, I left one part of the equation out, thinking it was self evident, maybe not.
I intend to drive the 18 speed, single overdrive in 17th gear/direct drive/1.0 ratio and use the overdrive only when I need to do better than 57 mph. I was wondering what speed that .86 would do in this circumstances, never more than 80.
Sorry for the confusion.
Page 1 of 5
