Minimum (4/32") Rear Tire Depth Measurement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SilverBulletBand, Oct 26, 2019.
  1. SilverBulletBand
    SilverBulletBand Light Load Member
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    WHERE exactly is the tread depth measured to constitute it DOT legal > 2/32" ?
    A rear tire on my truck looks like the attached pic. Worn out on SOME edges.
    jamespmack Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Measured in any major tread groove. Drives are 2/32. Steers are 4/32 min depth anywhere measured.
  4. jamespmack
    213,295
    4/32" on steers. 2/32's on anything other than steers in any 3 spots of main thread. But it's time to take them off. Get wheel bearings checked and adjusted. Put a closed shoulder tire back on unless your off road.
  5. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    So, that inner tire with the edges worn down is shot.
    I'm trying to get my boss (that sits next to the copying machine) to squirt some pennies out his butt and get the tires replaced. :rolleyes:
    D.Tibbitt Thanks this.
  6. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
  7. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    I would Rotate that pair of tires.inner to out.
    That might smooth out the edge wear.
    Those tires don't look bad enough to replace.
    But then. I spend my money on repairs.
    Doealex and SilverBulletBand Thank this.
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    The real answer is it depends on the DOT officer. Your not going to win an argument with them.
    SilverBulletBand Thanks this.
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    hammer down. get them wheel bearings check and 3 axle before new set.
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Get new and trade in for casing value. Especially if a good name brand tire. No use losing 50 to 60 bucks a tire on its value. Tell the boss to grunt hard. Lol.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    lord no. you got issues going on. if you dont fix it. the new set will do the same
