mini fridge questions
Discussion in 'Questions From New Drivers' started by Wade73, Feb 9, 2015.
  1. Wade73
    Wade73 Light Load Member
    140
    42
    Jun 11, 2014
    Springfield, IL
    I just bought a haier 1.7 cu ft mini fridge for the truck. It isn't a cooler. It's an actual fridge with compressor. I have a 1500 watt inverter to power it. Have a coutouple questions: 1) where should i put it? I'm thinking passenger seat or on the top bunk. It is too wide to fit in the sleeper cabinet. Which place would be better? Should i secure it with bungee cords or straps or something? 2) will i be able to let it run overnight with the truck off on my 10 hour break? Since it shuts on and off I'm thinking it should use less power than an iceless cooler.
    Any comments or feedback will be greatly appreciated!
  3. brian991219
    brian991219 Road Train Member
    2,999
    6,090
    Aug 10, 2013
    Lords Valley, PA
    1) Where ever it is out of your way, personally I think on the passenger seat obstructs too much of my view out the window so I would go for the bunk.
    2) Yes, most definitely secure it, last thing you want is a fridge, or anything else, coming at you in the event of a crash, or even just a hard brake event could slide it off the bunk and damage it.
    3) Depends, if your inverter is high efficiency it may power it, also depends on how cold you keep the fridge, how full (a full fridge cycles on/off less often), the condition of your truck batteries, any other electrical load you pull while parked, many factors. You also may find a 1500 watt inverter is a little light when the fridge first starts the compressor, they surge and draw a lot of power. This can lead to early failure of your compressor or inverter if they are not rated properly.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Some companies will take out Passenger Seat for you.
  5. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
  6. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    I drive a ProStar , I have mine ratchet strapped to the top of the cabinet behind the passenger seat
  7. Tall Mike
    Tall Mike Road Train Member
    7,452
    35,224
    Aug 20, 2014
    The Hammer Lane
    I ratchet strapped one to the floor after I removed a cabinet...
    but I owned the truck so it was an owner approved mod ;)
  8. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    Should this question have been asked before you bought it.:smt075 Yes, I am the one that had to bring it up.
    I removed a base unit so my fridge would sit on the floor out of the way. You have to secure it well, use a strap and not a bungee If you have to put it up on the bunk then put it behind a cabinet so it won't fall off in an emergency stop.
  9. 77fib77
    77fib77 Road Train Member
    11,276
    73,090
    Jul 7, 2010
    St Louis
    Harbor freight has cheap straps. Good for a fridge.
  10. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    I think I'd recommend it be placed out of the sun. Don't want it working any harder than needed.
