Milky Gray Differential Fluid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TheBaron97, Jun 27, 2020.
  1. TheBaron97
    TheBaron97 Light Load Member
    53
    42
    Jun 22, 2020
    Williston, North Dakota
    The oil in both of the differentials to this Peterbilt 379 I bought is a creamy milky color. I've never seen this in a differential before and I'm wondering what the cause is and if I need to change it. Also what should I put in to replace it if I do change it? I've heard that you should never change a transmission's fluid unless you really need to, because it can help an old transmission last longer to use its old oil. Does the same go for a differential?
  3. bad-luck
    bad-luck Road Train Member
    3,252
    5,954
    Nov 16, 2013
    Baltimore, Maryland
    Change it immediately. It is water in the gear oil
    Rideandrepair, pavrom, tj379 and 8 others Thank this.
  4. TheBaron97
    53
    42
    Jun 22, 2020
    What do I put in there? Just the Lucas brand hub oil? Or is there something that I can get more bang for my buck with?
  5. TheBaron97
    53
    42
    Jun 22, 2020
    I don't think so, however I work in the North Dakota oil fields and sometimes you drive through water a foot or two deep.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I do find it odd that both diffs are milky colour.
    As stated above, most likely was the diffs under water?
    Rideandrepair Thanks this.
  7. Shawn2130
    894
    1,892
    Sep 20, 2015
    Ontario
    2 feet is already close to the vents on the housing or above that level.
  8. bad-luck
    3,252
    5,954
    Nov 16, 2013
    Baltimore, Maryland
    Depending on the year of the truck. I think but I am not sure, but trucks manufactured after 1997 are synthetic gear oil. There should be a round tab around the oil fill nut that tells you what it takes. But I would recommend synthetic. You can call Peterbuilt give them the last six of your vin they will tell you
  9. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Change the tranny fluid too. I've heard that about automatic transmissions in cars or pick-ups but don't think it applies to manual. 50wt synthetic in trans and 70wt synthetic in rears I think
    Rideandrepair and Shawn2130 Thank this.
  10. AModelCat
    154,534
    Friendly word of advice - clean fluid is ALWAYS better than contaminated fluid. Especially in something like a transmission.
    You're going to want to find out where that water ingressed from or you could potentially waste $$$ on fresh fluid. Could be from a faulty breather. I would also make dang sure to inspect the top side of the diff housings. If trucks aren't washed often I've seen them rot right through. Usually under/around the torque rod pedestals or where the suspension attaches to.
    A5¢, tj379 and Shawn2130 Thank this.
  11. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    Water... You got water in your differentials. Drain it and check all your seals... Might even have to split your diffs to reseal the 2 halves.
