So I’m not so naïve and new to trucking that I realize there’s a little bit of shadiness that goes on in this industry amongst trucking companies. It’s just something we all have to accept and deal with as we go. Here’s my issue.I get the whole actual miles versus practical miles and pay. For example when I run an 800 mile load, it doesn’t really bother me when it’s dispatch at like 782 miles or something. IT DOES bother Me when the next time I get the same load from the same destination and pick up point and it’s 761 miles. Lol OR, I log in and see the website showing it as an assigned load to me at say a much higher mileage then what it came through on the Qualcomm as and ultimately my paycheck.
Long story made short, I believe I’m getting ripped off a few miles here and there. On average probably A hundred miles per week on up to like 150 miles or so. Some loads are 50-60 miles off...And this is not figured against actual miles but their own practical mile calculations. So my question is how would you all handle this? I don’t really consider myself that new at a year and a half in. But I do value my job overall. But, the way I’m wired I don’t like getting ripped off I don’t like when people think I’m an idiot, it just rubs me the wrong way!!!
Have any of you had to deal with this issue? How did you call out your dispatch or supervisor etc? I’m one of those numbers people and if you’re ripping me off 100 to 160 miles on average per week and you look at that over a yearly basis You’re talking about several thousand dollars out of my pocket. I already feel like for the job I do I’m underpaid compared to what other drivers are getting. Why? Because I’m better at my job then them, even if they’ve been driving longer. I’m good at driving. I’ve ran every load on time and NEVER EVER turn down a load and I do whatever they ask, running very time crunched loads and do what it takes.
Miles are off and change.....
Discussion in 'Questions From New Drivers' started by Lennythedriver, Mar 16, 2020.
That sucks.
You need to decide are these issues honest mistakes, in which case you send a message indicating they made a mistake and please adjust your pay. Make sure to detail the facts and then ask someone to adjust your pay or explain why no pay adjustment is coming. If you are very closely watching the details, and they know it, they may fix the problem or simply stop "screwing up" on your check.
If you think this is a deliberate practice, find another job. Don't make it an issue but warn other drivers. When you warn don't accuse the company but say something more like "have you noticed if XYZ is happening on your paycheck?"
This is why the most important thing to do when looking for a job is talk to current drivers. One of the questions to ask those drivers is "have you noticed the company shorting your miles or frequently "forgetting" to pay you for some of your work?"Lennythedriver Thanks this. -
Ask for an explanation
if it was an honest mistake, some of the loads would have higher miles, correct? LOL it’s happening with every single load now. I don’t think whoever’s doing it understands that I can login and see what the miles are supposed to pay. They probably don’t realize I figured that out. -
Could be they are skimming stuff off to screw you out of money, ask a higher up in the company about it. "I did this load from A to B 3 times and each time it had different paid miles from the exact same shipper to exact same receiver, why is that?"
Is the route you drive for each load planned by the company? If so, maybe the differences could be due to slight differences in the routing by the load planners. Including things like fuel stops away from a direct path from zip code to zip code (which is how most companies calculate miles). -
Well u said u feel like ur underpaid for the work u do and that is the problem. There is to many good companies out there that will pay u what u think is fair . Why stick around at a place when u feel ur underpaid and on top of that they are cutting ur miles ? For what its worth most companies only pay zip code to zip code . U are always gonna be short or long on some . And they are always gonna caluculate the shortest route even if that route takes the longest and burns more fuel. Which happens out west .
Deere hunter Thanks this. -
You get paid either HHG(house hold mover guide) which is zip to zip or PCMiller miles (aka practical miles). With HHG you get a few percent less miles vs practical miles. But even practical miles sow you a little short vs actual miles. Both these systems were put in place to give consistency in routing miles from place to place so quoting costs are standardized on loads.
If there’s a significant difference, then you may not be following the route correctly. Often times, the system uses shortest routing, which takes you the slow way via small towns on US or State routing, even though using a turn pike or interstate would save you an hour or more. NJ is a great example where you may be routed via US1 even though NJTP would save a ton of time. -
I had a similar trip. I had delivered in Phoenix and picked up in Phoenix. Paid 1mi on a 15mi deadhead.
Linte_Loco Thanks this.
