mid-roof sleeper - height?
Discussion in 'Ask An Owner Operator' started by bbmyls2go, May 11, 2013.
  1. bbmyls2go
    bbmyls2go Medium Load Member
    393
    96
    Feb 19, 2006
    Chattanooga, TN
    Can someone who runs a mid-roof cab tell me what your clearance height is? I'm building a barn with two doors, one will be for a 13' 6" clearance for a condo and the other for a 9' 6" clearance for a vintage fire truck. Was thinking of making that lower door high enough for a mid-roof. Found a spec on a mid-roof Coronado called BBC that says 132" and am not sure if that is the ground to roof clearance or not (11').
  3. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    The BBC is Bumper to Back of the cab.
  4. kwswan
    kwswan Road Train Member
    1,900
    9,843
    Jul 26, 2009
    mcminnville,tn.
    Go ahead & build both the same height, that way you won't have to worry about either one.
  5. bbigcnote
    bbigcnote Light Load Member
    194
    107
    Dec 29, 2008
    northeast, missouri
    this or you will wish you did later.
    Blind Driver and cetanediesel Thank this.
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    My stack is set at 12'6", and is maybe @18" higher than the roof of the sleeper. That is on a Columbia midroof XT.
    if you need a specific measurement, let me know via a PM and I will measure it for you though
    Martin
  7. Allan M
    Allan M Medium Load Member
    453
    283
    Apr 20, 2009
    My Kenworth T2000 is 11' 2" without the aerodynamic cap on top.
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Most mid roofs have stacks that are 12'4 - 12'7. You would want it to be 13 anyway. If its not to much more just got with full height for both.
  9. leftlanetruckin
    3,607
    3,160
    Mar 12, 2009
    Depends who owns the truck, and what you haul.
    Grain trucks have them lower than that to miss overhead stuff when they load, us low boy haulers have them wherever we want them, a lot of trucks have weed burners, and so on.
    Dont ASSume everyone drags a van around and drives a company truck.
    Martin
  10. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Sounds to me like the OP wants to improve versatility of the building, in that case I'd go with 14-15' high by at least 12' wide on both doors. For a mid roof you'd want at least 12' high, if you can fit the extra 2-3' you'll be kicking yourself later if you don't get it. The shop I used to work at had 15' x 15' doors, had a little room on each side, but not as much as you might think.
    cetanediesel Thanks this.
  11. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    You can't build a shop too big nor the door too tall or wide.
