Meritor rear end
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Novaktrucking66, May 30, 2021.
  1. Novaktrucking66
    Novaktrucking66 Bobtail Member
    7
    I have my semi jacked up all three drivers accept the right front spin the inter axel shaft my diff is disengaged the right front spins. Makes noise and tries to spin right rear ad interest axel shaft but can't? Any ideas
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    my head is spinning too
    Dino soar and AModelCat Thank this.
  4. AModelCat
    154,581
    Yeah I'm not following either.
    What are you trying to diagnose?
    Dino soar and Don379 Thank this.
  5. Novaktrucking66
    7
    Rear end issue front passenger driver spins freely makes metallic clanking and attempts to spin the shaft between rear ends but can't all other drive wheels spin this shaft? What can the cause be
  6. Don379
    714
    1,286
    Jan 7, 2021
    the other shafts will spin that shaft becuase it doesnt take much effort with that shaft being shot. but with that shaft being that it is shot doesnt have enough teeth depth to spin over the other wheels. Pull the driveshaft and inspect the splines. Its only a few bolts. If those splines check out, your gonna have to get the reaer rebuilt
  7. Novaktrucking66
    7
    Both pumpkins or just front one and could it just be the spindel to that one corner or r u saying it's the read driver
  8. Novaktrucking66
    7
    So u say to pull the shaft between rear ends and look for what I'm fairly mechanical inclined but never done rear ends although not much scares Me
  9. Don379
    714
    1,286
    Jan 7, 2021
    from what i can make of what you are describing, sounds like you need to pull the front axle shaft on passenger side. Sorry i said driveshaft by accident. Remove the bolts that bolt it to the hub. And slide the thing out of the bore. inspect the splines
  10. Novaktrucking66
    7
    That was what I thought if it's shot u.suppose I can get away with replacing this one shaft the rest has more that normal slop buy I really don't wanna rebuild at this moment can't afford it or the down time
  11. Don379
    714
    1,286
    Jan 7, 2021
    Should only take you 5 minutes to to pull that axle out and check the splines. I always use a paper gasket reinstalling axles. some guys like to fiddle with rtv. Never had leaks with paper
