I have been driving a mixer truck for about 3 months now and the hard seat is staring to do a number on my rear end. I looked for memory foam seat cushions on Amazon but oddly most of them do not have straps to die the seat cushion to the existing driver seat. Does anyone here use a memory foam cushion? How are you securing it to your seat? Pics and links welcome. Thank You.
Memory Foam Seat?
Discussion in 'Questions From New Drivers' started by Labrador, Nov 11, 2022.
It is OK to make things fit your needs instead of buying someone's over-priced truckstop version. -
tscottme Thanks this.
This amazon item shows what I found to be durable and comfortable enough for me. The purple cushion is silicone and the cover protects it. My one complaint, and it may not apply to you. I am hot natured. I like temps in the 60s or less and feel too warm in the mid 70s. Sitting on the cushion I have causes a certain amount of "swampiness". I'm not saying the cushion/neoprene cover is causing more swampiness than I would have on some other cushion, but the cushion/cover don't cause less swampiness than no cushion. It's probably my issue and not the cushion. Since the silicone and cover on my cushion don't absorb moisture scuba diver wetsuits are made of neoprene, the cushion/cover don't smell worse and worse over time. I suspect a memory foam cushion, if I used one, WOULD absorb more and more moisture.
BTW, the most common memory foam seat cushions on Amazon that share this sort of shape all seem to share a similar over-engineered shape with deep contours and a cut-out under your tail bone. IMO, that's just a dazzling gimmick to suggest super geniuses designed this thing so don't mind paying lots of money. They may work well for you. I don't know. -
