MCS-150 Bi-Annual Update Missed Oops
Discussion in 'Ask An Owner Operator' started by Siinman, Dec 7, 2024.
  1. Siinman
    Siinman Road Train Member
    5,156
    12,909
    Mar 5, 2017
    Kansas City, MO.
    Well I screwed myself this time. Had troubles logging in a few weeks back and had sent in for a new pin to update my MCS 150. Then had to wait to get a hard copy of my license since I had to renew it.
    Thought I would be fine since I updated it every year instead of every other year. Turns out they dont care about the every year but only the Bi. Got busy and was gonna just knock it out when I did my plates this month at the same time.
    Now the website is screwed up and you have to send in a Ticket on the FMCSA website with the documents. I read it can take 5 business days to get it back up but nothing on the FMCSA website on time frame. Anyone have to deal with this? I am kicking myself in the ### for this one. Can't believe I managed to screw this up.
  3. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    Just get it done and keep on trucking in the mean time. You’re not the first person and won’t be the last.
    Its important to not mess up obviously. But, there are much worse things to overlook then the MCS-150.
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Kinda funny if you update your info on your own it doesn’t reset the clock sort of speak.
    W923, Siinman, nikmirbre and 1 other person Thank this.
  5. Rontonio
    Rontonio Road Train Member
    6,248
    45,378
    Aug 9, 2009
    I am in The same place as you…
    have to hand write it and fax it to them - just retarded
    Con707904, Oxbow and D.Tibbitt Thank this.
  6. D.Tibbitt
    140,665
    I can make you feel better..
    took my truck off the road last year in July. Decided I didn't need to pay for my 2290 since the truck wasn't going to be worked for awhile, since I run out of money.
    Well I still want to keep my authority active and my irp/ifta active, I totally forgot I needed the 2290 to renew my plates !
    Went to file it last minute , of course the irs is closed from mid December to mid January. Wasn't able to have it accepted by the government until mid January. now my IRP is overdue since i cant renew without it, and then on top of that I got charged for 6 month of late fees by the irs as well as 6 months interest... turned a $550 payment into over a $1700 f up.
    When I filed this year I realized you can claim an "exemption" if truck is worked for less than 5k miles or whatever the threshold is... doesn't even cost any money but you still get all the paperwork so you can renew plates..
    Yeah I am a grade A dumb ###
    W923, MACK E-6, Judge and 3 others Thank this.
  7. Iamoverit
    Iamoverit Road Train Member
    1,530
    3,309
    Oct 31, 2023
    I always did it yearly just to make sure I wouldn't forget. You're right though. They could care less how many times you do it but it better be every other year no matter what method you choose. I would certainly keep running as normal but get it squared away ASAP before they fine and/or revoke. If you remedy the situation as soon as you get your password letter you'll have no issues.
    Siinman, Oxbow and D.Tibbitt Thank this.
  8. Rontonio
    6,248
    45,378
    Aug 9, 2009
    tje password does no good - the system does not allow you to do it electronically right now. I have my password and the functionality is removed
    Con707904, ElmerFudpucker and Siinman Thank this.
  9. Iamoverit
    1,530
    3,309
    Oct 31, 2023
    Something doesn't sound right. You should be able to update your MCS150 online with that password any time.
    It looks like they may have changed the process. I always logged in from Safer and did it that way. It looks like now they want you to use something called, "Ask FMCSA", fax or snail mail.
    https://www.fmcsa.dot.gov/registration/updating-your-registration#biennial-updates
    Siinman Thanks this.
  10. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    No, you’re not. As you know the best lessons learned are often times the ones that cost you the most! Hopefully you can get back into the game and find something that works for you.
    Grumppy, D.Tibbitt and Siinman Thank this.
  11. broke down plumber
    2,528
    17,839
    Jan 25, 2024
    Gov't agencys create all these hoops in the hope you will F it up so they can fine you . My take anyhow.
    Con707904, W923, Speedy356 and 7 others Thank this.
