Maxxforce DT ICP adaptation in-range fault
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PowerstrokeDiesel67, Nov 16, 2019.
  1. PowerstrokeDiesel67
    PowerstrokeDiesel67 Bobtail Member
    9
    Nov 16, 2019
    Got a 2012 Maxxforce DT9 throwing a 164 13 code for ICP adaptation in-range fault. It’s been doing this for quite a while, high pressure oil rail has been resealed and a new ICP sensor installed with no change in how/when the code comes and goes. Starts fine cold or hot, no drive ability concerns. Hoping HeavyD or one of the other Navistar experts can chime in.
    Thanks in advance.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Actually, this code is now obsolete and no longer used. You need to have the ecm calibration updated to fix this.
    spsauerland Thanks this.
  4. PowerstrokeDiesel67
    9
    Nov 16, 2019
    Ok thanks. The owner says the ECM has already been “modified” so I’ll tell him to go back to the original shop that worked on it. Thanks again for the quick response.
    Heavyd Thanks this.
