Maxxforce 13 Oil in coolant, no oil pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Auralogi, Jul 9, 2020.
  1. Rooster57
    Rooster57 Bobtail Member
    7
    Dec 9, 2020
    Would this cause pressuring up and blowing out all coolant from reservoir ?
    Same engine 2013 Maxxforce 13 . This happened to me last week.
    Haven’t pulled intake hose yet as the previous suggestion. No leaks or smoke
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Air compressor or cracked cylinder head will cause this.
  4. petefan4000
    petefan4000 Light Load Member
    107
    129
    Dec 2, 2020
    Swap it for a C13 or a DD13.
  5. gege71055
    gege71055 Bobtail Member
    11
    Jul 12, 2017
    I have what looks to be coolant in my oil and it’s also pushing coolant out the reservoir. Would this apply to my issue also. Same year and engine.
  6. Heavyd
    7,751
    6,184
    Feb 4, 2009
    Failed oil cooler would be more likely.
    Oxbow and petefan4000 Thank this.
  7. petefan4000
    107
    129
    Dec 2, 2020
    Probably the oil cooler.
  8. semi experience
    semi experience Bobtail Member
    2013 mf13 engine ,I replaced bad head and I now get about 1/2 gallon oil a week in water reservoir after 2500 miles. Could this head be defective with cracked or bad machined oil port ? no oil in reservoir prior to changing old cracked head. Didn't disturb oil cooler housing when replacing head so i feel like it isn't the problem. Any suggestions on where the oil is entering cooling system?
  9. Heavyd
    7,751
    6,184
    Feb 4, 2009
  10. semi experience
    I originally thought so too. Got one laying in floor to swap it and see if that solves the problem. Thanks for the help, will keep you posted if not solved with oil cooler replacement
  11. Barrolloff
    Barrolloff Bobtail Member
    I have a 2014 maxxforce 13 that puts soot in the coolant reservoir only under boost
