Anyone figure out how to maximize driving time using split sleeper?
I've seen drive 10 hours, sleeper 8, drive 6, sleeper 2,
Is there any trick to squeeze out a few more hours per day? I drive Florida to California and back so could play with a few options to try to get the most hours per cycle
Maximize driving time with split sleeper
Discussion in 'Experienced Truckers' Advice' started by Oilfieldmike, Sep 27, 2017.
Page 1 of 4
So you drive one hour after that 8 hour break, and take a two-hour break, that will get you 10 hours back.
In summary, the split sleeper does not get you more hours than 11 to drive in a one day period.poppapump1332, CrappieJunkie, Dave_in_AZ and 2 others Thank this. -
Split sleeper comes in handy where there are very specific circumstances. Example, I park six miles from my customer and I still have 3 hours left on my clock but my appointment isn't till tomorrow morning. If I take a 10-hour sleeper break I'll be late for my appointment, but if I only take an 8 hour break I can make the appointment on time cuz I'll have 3 hours available to do it in.
I hope that helps.fargonaz, Dave_in_AZ, Lepton1 and 1 other person Thank this. -
You can maximize your time that way, but not drive more hrs. But you can skip your 30 minute break.
Drive 7hrs
Take 8hr break in sleeper
Drive 4 hrs
Take 2 hr break
RepeatDave_in_AZ and Lepton1 Thank this. -
The key points of the 8/2 have been well noted above. Bottom line is, at best you can shave a half hour per day off of your end arrival time if you use the 8/2 judiciously. To me in my work, the 8/2 is only used to meet critical appointment times or avoid traffic, where a 10 would be a problem and I know there will be a good opportunity/chance to do a 2 later in the work day. Otherwise, I prefer to only do one 30-45 minute break then resume.
There are times when you must do this to meet appointments. Also, there are some who just prefer running this way daily as a matter of routinencmickey and RoadRooster Thank this. -
driverdriver, DoubleO7, Lepton1 and 1 other person Thank this.
The only way I've found to game the game, is if the run requires two shifts with a total of 15 or less driving, you can eliminate your half hour break if in you wind up in a good spot closing in on the 8th hour.
ncmickey Thanks this. -
10 hours off is so great, 2 hours to goof off, 7 to sleep and an hour to get woke up, in fact a 11 or 12 hour break is even better.
Even if you can master the split sleeper break, the 70 hour rule is gonna get you and you’ll see splitting your break was a waste of timeMudguppy, 12 ga, snowwy and 1 other person Thank this. -
If you drove for 6 hours, took an 8 hour break, then you'd have 5 hours left on your 11 hour clock. Whether you use the rest of that 5 is up to you. If you only drive for some or all of it, then followed by a 2 hour break... Then your clock resets for a fresh day.
If you break for the 9.5 hours like your last part says, only makes sense to take that final 30 mins if time allows so you're not worried about a split shift.
Hope that helps
Page 1 of 4
