I've added an over inflate switch for my airbags using a Air solenoid thats normally closed and added a T into my air bag fitting. This helps with picking up trailers that might be to high. Anyway What is the MAX air pressure i could fill these bags till before they pop? I'm wanting to add another Air Solenoid that shuts the air off in the Leveling Valve so my truck doesn't have to fight with building air.
Max air pressure in an Airbag?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, Nov 8, 2022.
Crude Truckin' and Another Canadian driver Thank this.
I wouldn’t worry about it. I’ve had as much as 110. Regularly 90.
HoundDog7, Crude Truckin', Another Canadian driver and 1 other person Thank this. -
Set a couple up like that to get into short. steep docks. Would raise up to the top of the shocks. 120-130 psi, never blew one.
Another Canadian driver and TruckerPete1990 Thank this. -
Another Canadian driver Thanks this.
Should say on the airbag itself. Usually 100 psi is about what most are rated for
beastr123 and Another Canadian driver Thank this. -
My Cascadia came from the factory with an over inflate switch. I've had them well over 100 psi.
HoundDog7 and Jubal Early Times Thank this. -
OLDSKOOLERnWV and Crude Truckin' Thank this.
beastr123 and stuckinthemud Thank this.
