Massive problems with JJ Keller ELD since Dec 14 firmware update
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Studebaker Hawk, Dec 17, 2017.
  1. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    Our company Trailer Transit starting installing the units in January, now have 180+ units in the field. JJ Keller instructed our drivers to update to the latest firmware on Thurs Dec 14 to convert the units from AOBRD to ELD status in preparation for the deadline Dec 18th.
    Many of our drivers are losing locations, data is being lost, some driving time or mileage is not being recorded, in short the system is unstable and not usable at this time. Problems appear to start when you certify and submit a log, which is prompted every day.
    Would like to know if any other companies using the JJ Keller Mobile ELD are having similar problems.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Typical jj keller programming. Been like that for years.
  4. Short Fuse EOD
    2,730
    8,493
    Jul 29, 2015
    Midwest
    Yes, we reverted to original. Now every time we log in, we decline to update. Less bugs, but some are still present.
    Studebaker Hawk Thanks this.
  5. Oldironfan
    5,777
    5,541
    May 22, 2017
    The update is for oilfield work or something like that. Never update unless you call tech support and ask them they are pretty good at answering 24/7. Or they call you back shortly.
    Moving Forward Thanks this.
  6. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    sounds like Apple IOS...lmao
  7. Oldironfan
    5,777
    5,541
    May 22, 2017
    It's usually a droid tablet.
  8. Moving Forward
    Moving Forward Heavy Load Member
    737
    727
    Jan 14, 2014
    New England, USA
    Yesterday was our first day running with the newly installed units, and I've noticed the the time stamp it's logging/recording if off by one hour and the miles are waaaaaaaaaay off. I hope we can get these issues resolved today.
  9. Studebaker Hawk
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    Things continue to be operating poorly. Companies that stayed with AORBD version are ok. Keller says you can't run AORBD and ELD rules same time same fleet, so if you have to add units after Dec 18, everyone has to be updated to ELD firmware.
    I would like to know if other systems can handle both sets of rules simultaneously.
  10. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    They either have to be a AORBD or and ELD, you cannot run both on the device. As for running both in a 2> truck fleet, the back end, the fleet side has to either run one or the other.
  11. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    I'll have to check into what exact unit we're running. Our keller logs are on our company phones with a separate unit permanently mounted in the truck and the only problem we have with ours is that our company also has an equipment inspection on our phones so when we take the phone out of the truck to use the inspection app we most times lose our log connection to the truck and have to spend the time to let it re-discover the truck.
    Occasionally upon logout at the end of the day it won't send in our logs which we're told isn't a big deal because supposedly it does that when we log back in the next day.
    We've been running these things since generation 1.
