mapping software
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by JaqDanielz, Jun 5, 2007.
  1. JaqDanielz
    JaqDanielz Bobtail Member
    I'm looking for a software or website that i can use to set up my routes efficiently. Something that can route 15-20 destinations in the quickest route available. Dose such a program exist? I'm new to this field and any feedback will help me.
    Thanks
    -Dan
  3. ruggrat007
    ruggrat007 <strong>Ms. Diplomacy</strong>
    153
    May 30, 2007
    So. Louisiana
    There is a comp. program called DeLorme. You should be able to get it at like Best Buy, or Circuit City. It's pretty decent. I hate to say this, but Flying J has a direction part on their web site, but of course it tells where all the Flying J's are on the route. Map Quest is well know, but it's got it's flaws as well.
  4. JaqDanielz
    i am purchasing a garmin streetpilot 2820 with multi routing capabilities. is DeLorme any different in what it offers?
  5. ruggrat007
    153
    May 30, 2007
    So. Louisiana
    I don't know, DeLorme is a program is for a laptop, and it has a GPS eye that interfaces with your computer. DeLorme is a very detailed program, and you don't have to have the eye unless you want to follow your route while you're driving.
  6. Steve & Lo
    Steve & Lo Medium Load Member
    358
    35
    May 22, 2007
    Tennessee
    DeLorme is the largest maker of paper maps in the world. They also make mapping software. If you are buying a Garmin branded GPS you will only be able to run the software that is on it. If you have a laptop you can purchase any mapping software you like and get a GPS unit that will either physically attach to your laptop or connect via Blue Tooth to your laptop. Or, you can buy a handheld computer like the Dell Axim X-51V(which I have) and use it for your GPS purposes. I didn't want to get tied down to just one type of software so I stayed away from the branded GPS units. I am in the process of getting the program for my handheld that is called CoPilot Truck. It has TRUCK specific routing algorithms built in to include restricted routes(which DeLorme Street Atlas 2007 does not), low bridges, truckstops, etc. that are all trucking specific. I have used DeLorme Street Atlas 2006 and it will send you down a pig path if you don't have it set just right. You can find GPS programs and GPS hardware by going to GPSnow. Oh, I currently am using the i-blue 737 Bluetooth GPS which has an operating time of 25 hours! No Garmin in the world will do that unless you have it hardwired. Don't spend $700 on a unit that is designed for a car.....It doesn't know that you can't go under that 12' 10" bridge in Chicago....all it knows is that's the shortest way to go..... CoPilot truck knows that bridge is there.
  7. notch
    notch Bobtail Member
    15
    Okay, as I thank everyone of you for your previous input, I have come across what' might be my final question before I take the Schneider Plunge. I've been researching their website and noticed that their trucks don't seem to have navigation systems installed in them...... As someone who does not know much of the country.....(or any of it besides Fresno CA.) I believe that I will be in desperate need of one. I've seen the nifty ones for passenger vehicles that go as far as telling you when to turn, and when you've arrived at your destination point. My question is......do they make systems specifically for Rigs? If so, would anyone know aprox. the average cost (including installation) Or am I doomed to be lost on the road? Once again, I appreciate all the help you've given me and prematurly thank you for your help on this subject. Thanks again.....Notch!
  8. Hill-a-billy
    Hill-a-billy Light Load Member
    187
    Jun 3, 2007
    South Carolina
    A good motor carrier map is cheaper, and works well. The company will also give you directions via the qual com. If you still think you need a navigation system, make sure you get one for commercial vehicles. Just because a road is there doesn't mean you need to drive a truck down it. Low bridges, or restricted routes can cause major headaches. Sorry, but I am not sure of the names of the truck navigation systems.:biggrin_25515:
  9. MGASSEL
    MGASSEL Road Train Member
    1,301
    211
    Mar 27, 2007
    Co
    well you can get a cheep nav system but you need a truckers map to check for truck routes.
    I have a cheeper nav system and I plan on using it along with the truckers map.
    I have Delorme lt-20 it is gps
    I get lost easy I want to know what exit that I need to take when I am comming up on it my program gives you a warning atleast 1.5 miles away to turn. and then Just watch out for the no trucks allowed signs and watch for the truck route signs then you should be fine.
  10. onexcop
    onexcop Light Load Member
    83
    12
    Jun 4, 2007
    Check out this link Notch (don't know if I'm suppose to give out links like this, but Cybergal or Wiseone will set me straight if i messed up).
    http://www.alk.com/store/whats_included.asp?sku=CPT9US-BT
    It's the "Co-pilot" made exclusively for big rigs. Read their cite for all the neat stuff it can do. Good Luck with Schneider and see ya out there! The wife and I are getting one soon.
  11. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    I have read in several places that the co pilot has some issues, and that for the 300++$ price it is not worth it. I have heard a 2 pronged attack on directions is best. A good map and the microsoft streets.
    1. Rand McNally Motor Carriers atlas. I have searched for the best price, seems that it is cheapest at Rand McNally. The delux version is 40 bucks at there own site, it is 50 or more on other sites.
    2. If you are going to have a laptop anyway, which is what the truckers co pilot uses also then check out this. Microsoft Streets and Trips, it comes with a GPS for your computer also, and you can find it for 100 bucks.
    This is the route I plan to use.
    1. Get the directions to site
    2. Map it on Streets, possably double check on mapquest.
    3. Check route that is given with the truckers atlas, this way you can see major construction, low bridges ect.
    4. Re Route my streets program as needed to avoid trouble areas.
    5. Then set to go
