30 years ago Mercedes Benz had a fully synchronized 10 speed transmission. This one you can shift the gears like knife in a butter, clutch is need it only for take off.
Why they stop producing them ?
Manual Synchronized transmission for a semi truck
Discussion in 'Freightliner Forum' started by Verdel, Apr 19, 2016.
Did they? You can get synchronized transmission in every truck in Europe. Volvo was trying to sell them here as I recall. But as far as using clutch for start/stop only that how I drive every day.
L.B. Thanks this. -
Drove them in European trucks we had in Iraq.
lee2442 Thanks this. -
I was told synchronized transmission added about 500 pounds to the weight of the truck. Never understood that until I got my first over weight load.
the size of the synchronizers needed would be pretty heavy to sync the heavy gears in those transmissions. not to mention i bet they would wear out quick.
You can't shift a synchro box smoothly without the clutch, and a non-synchro box will shift smoother, both with or without using the clutch smoother than a synchro box, IF you know how to shift. If you don't, then you need a synchro box!
JoeTruck Thanks this. -
I rather have non sync. That gives me the option to change gears quietly without the clutch. Saved me a time or two. But you absolutely need to know what you are doing or you gonna wreck it all.
Why stop at full sync? Get a automatic if you don't wanna shift.
