Mandatory drug and alcohol training
Discussion in 'Expediter and Hot Shot Trucking Forum' started by procharged392, Sep 27, 2019.
  1. procharged392
    procharged392 Bobtail Member
    45
    11
    Mar 7, 2019
    Every since I’ve registered for my DOT I’ve not only received endless phones but mail as well. I received a mail from Supervisor Compliance Training Department regarding a mandatory drug and alcohol training. I’ve yet to hit the road yet just trying to get my ducks in a row but my question is, is this a legitimate mail? Cost is $99 for a 2 hour training session online and if I don’t register I could be fined up to $10k.
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    check with the OOIDA if you are a member, maybe it is cheaper. i think that as an o/o you need to have a drug/alcohol testing set up for randoms, etc.
    it's called a "consortium" i think
    procharged392 Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    73,250
    164,503
    Aug 28, 2011
    Henderson, NV & Orient
    Yes, check with www.ooida.com
  5. procharged392
    45
    11
    Mar 7, 2019
    Yes, you’re right. I have to register with consortium. I came across this online, I’m hoping the below in red is true. My CDL test is at the end of the month so at the moment I don’t have a CDL but I’ve received 3 letters already. Just want to verify since I do receive a lot of mail stating I need to pay for this and that(junk mail trying to get money from people).
    • If you operate vehicles that require a CDL on the public roads and you have more than one employee in the company, you are required to get DOT Supervisor Training.
    • Owner-operators are not subject to DOT supervisor training. However, you are still required to register with a consortium for DOT drug and alcohol testing.
    • Employers need to ensure that the required content is made available to all persons designated to supervisor drivers.
    Based on the above consortium and the training are two different things?
  6. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Yea and they should be free, I know the one I'm in is.
    procharged392 and buddyd157 Thank this.
  7. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    means that you do not need to pay for that class.[/B]
    but once you hire someone to drive, then YES, you have to have that class.[/B]
  8. procharged392
    45
    11
    Mar 7, 2019
    Ok, well I don’t have my cdl yet and when do I’m only a single member LLC so looks like I can disregard the letter. It was abit scary when I read I can be fined. I will register for the consortium though.
    buddyd157 Thanks this.
