Maintenance Schedule
Discussion in 'Trucks [ Eighteen Wheelers ]' started by leviant0107, Apr 19, 2022.
  1. leviant0107
    leviant0107 Medium Load Member
    307
    206
    Oct 24, 2021
    Detroit, MI
    What would the negatives, if any outside of an increase in maintenance expenses, be to shorten a general maintenance?
    I.E. I googled a severe duty maintenance schedule that suggested a Classic Lube at 10k miles and shortening that to every 7500.
  3. AModelCat
    154,213
    Grease the truck every weekend. Guarentee ya you'll hardly ever change cam bushings, u-joints, kingpins or tie rods compared to guys who grease once a month.
  4. leviant0107
    307
    206
    Oct 24, 2021
    Detroit, MI
    Noted, I’ll put that in my notes.
    What about changing any of these parts out ahead of schedule? Damaging or beneficial?
  5. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    Most contaminants in engine oil are introduced during the PM. I don't think you're helping an older engine by changing before 10-12k, and a newer engine before 20k
    That money would be better spent changing common maintenance items when possible. Brakes, starter, u joints, wheel n bearings, bushings, etc, ad nauseum.
    Hell of a lot more to a truck than an engine and transmission.
    D.Tibbitt Thanks this.
  6. leviant0107
    307
    206
    Oct 24, 2021
    Detroit, MI
    So far I’ve been putting together a list of PM items and suggested maintenance intervals for heavy haul considerations. It’s all under the hood items. I’m going to look into the suspension, brake system, drive train items etc and do the same.
    Of course this is something I’ll cross reference with the suggested for whatever truck I purchase when I do get one.
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    I spent $250 per truck and put cordless grease guns in them. They paid for themselves in automatic slacks alone the first year.
  8. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Grease and oil are cheap. I Grease steer axle for sure once a week and whole truck weekly or bi-weekly. Try to plan breakdowns, getting under the truck weekly you will find small problems before they become big problems. I'm not a big fan of replacing parts for no reason but if they are showing signs of failure I'm not afraid to replace before they go completely caput. Replaced both rears when they started showing to much metal on the plug, they might have lasted 200,000 miles more or 50,000 who knows. But I'm not gonna just replace parts at X amount of miles. If you watch things you can usually spot small things before they become big things
    Diesel Dave, D.Tibbitt and AModelCat Thank this.
  9. AModelCat
    154,213
    Slack adjusters can last dang near forever if they get a couple shots of grease once a week. Once components are full of grease, hardly takes much to keep them full. I could grease a tridrive/tridem trailer on about 2 to 2.5 tubes of grease.
    Diesel Dave and D.Tibbitt Thank this.
  10. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    My grandfather was an auld sod Scotsman, wastefulness wasn’t something he tolerated a whole lot and I can’t remember even once being roared at for using too much grease. A big part of it is just being under them on the regular. You figured out there’s found money to be had there. I can’t remember how much stuff I came across and fixed while I was under there adjusting my brakes. I think in some ways automatic slacks caused more problems than they cured.
    BoxCarKidd and AModelCat Thank this.
  11. AModelCat
    154,213
    Yep, grease is cheap. $30 worth of grease a month is cheap compared to a u-joint grenading. By the time you factor in a new shaft, yokes, air bags, ABS modulators, labour and possibly a tow/field call it could be a $6,000 repair or more.
    Plus like was said earlier, you'll find things before they leave you stuck on the side of the road. Monitor components so you can schedule repairs when its convienient for you.
