Mack truck plastic mirror cover removal.
Discussion in 'CB Radio Forum' started by RJ33RD, Jul 24, 2018.
  1. RJ33RD
    RJ33RD Heavy Load Member
    857
    157
    Aug 27, 2009
    Baltimore, Md
    Hey Drivers I'm trying to figure out how to remove my mirror cover from my Mack truck so I can access the my Cb radio coaxial cable. Anyone have any experience with this? I already checked YouTube but I only saw videos for volvos and freightliners.
  3. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Im guessing it will be same idea..Mirrors will have to come off first then look for a clip of sorts..
    RJ33RD Thanks this.
  4. RJ33RD
    857
    157
    Aug 27, 2009
    Baltimore, Md
    I found out how to do it.. it's two plastic tabs one on top and the bottom, just pull those out and the plastic chrome cover will come off.
    Highwayman1224 and rabbiporkchop Thank this.
  5. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Now you just need one of these to pull the cable through the tiny hole.
    RJ33RD Thanks this.
  6. Tensleep440
    Tensleep440 Light Load Member
    113
    63
    Mar 29, 2018
    NE Corner of Texas
    Those look oddly familiar, oh! I use their big brother on coax when I’m climbing broadcast towers.
    RJ33RD get a pic to help out other who might have the same issue?
    RJ33RD Thanks this.
  7. ron_is_here2
    ron_is_here2 Bobtail Member
    On a 2018 mack truck roll your mirror all the way out you'll see two clips half way down unhook them pull your mirror off and the there's 4 screws take them out then the chrome cover will pop off
  8. Delta1up
    Delta1up Bobtail Member
    I have a 2018 Mack Granite dump truck and somehow managed to let the coax fall down inside the mirror so that I can't get to it without taking the mirror apart. The problem is after reading the posts above I have an idea of what to look for but I'm not seeing what the previous posters mentioned. I do see on the right side of mirror in between the mirror and the casing there is a clip that can be unfastened but I only see that one and don't want to get started not knowing if I can finish and get it put together again. Does anyone have any pics or more detailed description? Thanks!
