Mack Maxitorque 5spd question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jmillwood, Sep 4, 2011.
  1. Jmillwood
    Jmillwood Bobtail Member
    22
    Flowery Branch GA
    I'm looking at buying a 70 R model Mack to restore. It has a 237 mack with a Maxitorque 5 speed trans.. I dont know anything about this trans. I'm not going to be pulling anything just driving to shows.. I'm not sure how it geared. Would the 5 speed make the truck slow on top end? Would it be weak on the low end? Thanks for any info
  3. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    I worked at a limestone mine for awhile, one of our yard trucks had the 5 speed in it, I bet it couldve went 55 all wound out...lol.
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    There's a lot of spread between gears, low is very low, high is 1 to 1, the rest would depend on axle ratio.
  5. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    old 5spd and 6spds for that matter and direct drive trans. it would be a good guess that its mated to 3.87 or 4.17 gears with 3.87 reverse is all little fast thats is the only down side there should be a 60-65mph truck
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    237 is a very good engine, and fuel efficent for the year. The 5 speed Mack transmission is pretty much bullet proof. Unless heavy loaded, or taking off up a big hill with a load, just drive it like a 4 speed.
    You will have to rev the engine to 2100 in each gear, pull into netural, release clutch, shave, comb your hair, grab a bite to eat, make a phone call, and by then the engine speed will be low enough to get into the next gear. You will now be at 1200 RPM. Mash on it, watch the smoke roll out the stack, and do it all over again.
    If the truck has 10.00X22 tires, or 11X24.5 tires on it (both tires are the same size around), with 4.17 rears, it will run about 72 at 2100 RPM.
    jimbo47 and josh.c Thank this.
  7. Jmillwood
    22
    Flowery Branch GA
    My first thought was it would be a fun and simple little tractor to restore but then I got the thinking the 5speed might not be enough trans. Im not sure what size tires it has.. would it be possible that it has R20 tube type tires? Thanks for everybodys opinion..
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The Maxitorque was revolutionary when it first came out.
    Don't worry, 5 gears is plenty, I remember reading an article where an industry writer took one for a test drive with a Mack Engineer when it first came out and how unbelievable it was that the engine could pull at such a low RPM.
  9. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    if you bobtail or run empty it won't be a problem at all i owned 2 of them i used to run one in the dump business 72000 no prblem.
