Mack engines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Highwolf89, Jan 5, 2015.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    Hi I am not familiar with mack engines.. I am wondering how are these engines for owner ops... I am not custom to these engines just cat, Detroit etc don't know much about them... I am looking at a truck with a mack engine and would like some in sight are they expensive to overhaul?
    Thank you..
  3. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    there good on fuel. many parts still have to come from a mack dealer. they are cheaper to in frame than a cat but more than a Detroit.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    on the overhaul on my mack motor 2000 e7 460
    overhaul kit 3582.43
    thermostat kit 67.28
    cyl heads (2) 1888.90
    6 injectors 924.98
    labor total 6048.00
    just to name a few total invoice was around 16k
    original motor went to 945359 was in framed due to a dropped liner
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It depends on year. All new stuff is just rebranded volvo. Mp8,ECT. d13,d16. It's volvo. Older Mack engines. Econodyne maxi dyne were great engines thou.
  6. Highwolf89
    294
    61
    Jul 30, 2013
    Ac460 the truck has I am looking At
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    the ac460 seems to be a ok motor i know a couple people running them, there very similar to my e-7 but with egr and variable vane turbo ect. from one guy i know with a ac460 told me when i was looking to buy my mack. he said they had a few issues with injectors and a few other things but once all the updates are done they are good motors and at the age they are now all the updates have surly been done by now.
    the biggest issue with going mack is dealer support. if you have good dealer support in the area's you run it should not be a issue.
  8. Highwolf89
    294
    61
    Jul 30, 2013
    Well I am looking at a ch613 with that engine it's a 07. It's heavy haul spec that's why I am interested...and for a good price... Looking for something to get me back into cali... So I can move back home...
  9. Bthilges
    Bthilges Bobtail Member
    Iowa
    Does anybody have any insight on the longevity of a 2008 Mack mp8 engine? Seems like we've had nothing but problems with the emission side of things and now maybe looking to put a turbo on it after we've replaced the dpf and EGR system...are we throwing money away by sticking it into this engine? Thanks
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    many Mack engines are still on road in Ukraine. The most popular are E6 and E7.
    E9 is rare.
    Early with Bosch Injection pump and later EUP (Bocsh MS6) engines are reliable.
    Later Mack MP/Renault DXI series engines are really Volvo engines assemblied on Mack/Renault plants. They use a bit different calibrations, aniway, the same engine with a bit different valve cover and oil pan.
  11. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    Mack has a rebuild program out now if you let them go through the motor, trans, or rear ends or also if you but a Reman you get same warrnty as a new truck on that piece. 07 was a decent year for egr main troubles was egr and turbo, fuel lines and belt tensioners can be a headache due to under hood heat
