Mac trailer what do you think
Discussion in 'Flatbed Trucking Forum' started by ford06, May 10, 2018.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    thinking of pulling the trigger on a new mac 48 foot spread flatbed chain pop ups and j track2 boxes inbetween axels 18 inch kingpin setting dump valve front axle 12 winches per side 15 lights per side anything else anyone can think of that would be good or anthing you think i might not need thanks
    Tug Toy Thanks this.
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    If it's new have them put the boxes forward of the axles. They just get in the way of working on stuff or inspecting stuff when they are between the axles.
    Highway Sailor, stwik and ford06 Thank this.
  4. SleepyJ77
    SleepyJ77 Light Load Member
    96
    48
    Jan 18, 2018
    They make a good wagon. Used to live right down the road from the plant. I personally think they make one of the best on the road.
    ford06 Thanks this.
  5. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    I would put the dump valve on the back axle, and a lift on the front axle.
  6. ford06
    39
    13
    Mar 8, 2017
    yes i ment to say dump on the rear axle do you think it would be worth putting a full lift front axle ive had the rear dump before helps on turns and tight spots never had a full lift axle though
  7. mslashbar
    599
    802
    Jul 22, 2009
    elizabeth,co
    It saves a lot of wear on your tires if you run around empty very much.
    ford06 Thanks this.
  8. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    The doors always seem to get wrecked on the ones between the axles too.
  9. Ruthless
    Ruthless Road Train Member
    8,784
    85,934
    Aug 28, 2010
    The City.
    What are you doing to wreck them?
  10. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Its just seems like every other one you see they look like the door came open going down the road or something. I haven't ever pulled one, simply an observation.
  11. Ruthless
    8,784
    85,934
    Aug 28, 2010
    The City.
    I have pulled spread axles with boxes between the spread for years, and what's more, I pull steps with boxes between the spread and mounted low.
    Never had any issues.
    I have one box mounted on my new flatbed it directly in the middle. Because the rear axle slides forward and therefore I can't mount something between the axles.
    If you drive around with toolboxes open and crashing into things you'll have problems no matter where you mount anything.
    I'm far from the best trailer trucker out here n I ain't having problems.
    Grubby, ford06, stwik and 4 others Thank this.
