M2 Code 3031 / DEF Temp Sensor
Discussion in 'Freightliner Forum' started by anatorian, Sep 22, 2012.
  1. anatorian
    anatorian Bobtail Member
    Hello,
    I've got a CEL and a SPM code of 3031 which is invalid DEF tank temperature. Of course this also means no DEF consumption.
    Is there anything I can do to remedy this short of replacing the sensor? Check connections etc? Where is the sensor located?
    Thanks
    Also SPN 1569 and 3363 which I believe are all related to this DEF tank temp.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    DEF tem. sensor is installed in DEF tank intake column. it is combined with DEF level sensor. So start with connector. it is weak thing becouse if DEF was spilled on cooper wires they gonna be corroded.
    What engine do you have? Cummins ore Mercedes?
  4. anatorian
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    so you should have small DEF tank under cab and it is made of plastic and DEF intake unit is held with big plastic nut.... wires run to uftertreatment unit.... inspect all this stuff
  6. pittbull670
    pittbull670 Bobtail Member
    31
    8
    Dec 27, 2015
    I have a volvo d13 2013 with code sa0 spn 3363 fmi2.any idea what is this or I can continue driving?no check engine or vehicle messages.thank you.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have no easy answer to your quation.
    This is AdBlue tank temperature problem.
    U need Tech Tool to read freeze frame of faut code and tell me temperature of DEF recorded
    may be really frozen fluid cant be melt with coolant flow, may be bad coolant valve ore may be really faulty DEF tank sensor built in sender unit
  8. pittbull670
    31
    8
    Dec 27, 2015
    I have have the truck in the shop today. The code was gone next day. The service manager told me they are going to test the DEF pump make sure is working. He thinks either the heater for the DEF or the temp sensor could be the problem cause I used enough def even more than usually so pump is working for sure.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    dealers like to swap parts to solve problem one by one.... u know
