M11 ignition start wire. Does it go thru the ecm first?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Mar 2, 2014.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    458
    288
    Feb 12, 2011
    Hillsboro Oregon
    1995 FLD 112, M11 cummins. I have full 12 volts at the push button start switch both into and out of the switch. But I can not get any voltage to the activate pole on the mag relay. Does the wire leave the push button and go into the ecm before going to the mag relay?
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    no.direct to the magnetic switch on fld.easy to run your own wire if you don't want to find where break is.good luck.
  4. Deezl Smoke
    458
    288
    Feb 12, 2011
    Hillsboro Oregon
    Thanks for the quick reply. Is it common to have this wire beak somewhere?
  5. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    it's common for wires to break anywhere. weather and corrosion wreak havoc on electrical. usually only happens on connections though. but i've seen wires break in the insulation where there's no connector.
    Heavyd Thanks this.
  6. Deezl Smoke
    458
    288
    Feb 12, 2011
    Hillsboro Oregon
    I found the issue. Seems the previous owner or company, either had an anti theft device, or some sort of satellite controlled non start thing installed. Does a qualcomm have something like that? Anyway, I traced enough wires to find it and will remove it so all will be well again.
