Apparently the 2008 Powermaxx11 I drive is a gutless wonder and this one really has no power. According to specs I should have peak power around 1300rpms. It's just a dog. I am thinking about using Lucas Fuel Treatment for a couple of tanks hoping that any clogged injectors get cleaned up. Common power related issues seem to involve low fuel pressure, air in fuel system, clogged cv/egr, sooted turbo fan basically just clogged stuff. I have used Lucas in gasoline vehicles for decades and have experienced the benefits first hand. A local diesel mechanic I spoke with seems to like it. Any thoughts on this?
Discussion in 'Questions From New Drivers' started by Ullihundi, Jan 15, 2017.
There are expensive pills that will increase schlong size by 70% too ... if you buy and take enough of them, of course.
TGUNKEL, scythe08, Lepton1 and 1 other person Thank this. -
May I suggest a few extra fuel filters and wrench.
I'm wondering, may it is my boredom today but are you an owner?
Or just a driver? -
Lepton1 Thanks this.
It also could be that it is tuned down to an economy mode to save fuel. If that's the case no amount of money you put in it to clean will help.
Ullihundi Thanks this. -
Also the tractor was sitting for about a year.
Lepton1 Thanks this. -
Ask the owner when was the last time he "ran the rack" (did an overhead). It should be done about every 100K miles. That can resolve many issues.
Regarding fuel additives I have used two with good effect. Marvel Mystery Oil is an excellent lubricant.
Xtreme is another product I use in fuel, oil, hubs, transmission, and differentials. It is heat activated and bonds to the surface of hot metal, coating it to reduce friction. It's expensive, but you only use a little each treatment. It's hard to find, I pick up a gallon anytime I can at the Petro in Joplin, MO.BUMBACLADWAR Thanks this.
