Lube oil for Fuller 8LL transmission?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bigfoot62, Nov 23, 2011.
  1. Bigfoot62
    Bigfoot62 Light Load Member
    92
    29
    Oct 29, 2011
    Louisiana
    Changing the oil in a Eaton/Fuller 8LL transmission. ('95 KW T800 truck)
    I just got this truck, and there is no manual. I was planning to use 75w-90 synthetic. Is that OK? Anything better?
    Thanks.
  3. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I think most people use 50w. I use 80-90 in mine. I prefer the heavier weight in mine since it's an off road truck and used only in warm weather.
  4. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Go to roadranger.com and download Eaton's lube manual for your tranny.
  5. The Gryphon
    The Gryphon Heavy Load Member
    826
    445
    Nov 3, 2011
    Better still, contact an AMSOIL dealer and put really good stuff in it. PM me if you want a referral to one. They can tell you what and how much you need and help you get it.
  6. thehammer69
    thehammer69 Light Load Member
    53
    15
    Oct 31, 2008
    Goose Creek, SC
    the 50 weight rating of transmission oil is a different scale than the gear oil rating that is used in our differentials. Basically the 50 weight transmission oil use the same SAE scale that engine oil uses...which is different from SAE scale of gear oil. If you look at the product data sheets published by the lube makers, there should be a specification comparing each's viscosity using the same viscosity scale. You will discover that they are close to identical in viscosity.
    Check out this chart and it will be clearer:
    http://www.bobistheoilguy.com/viscosity-charts/
  7. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    Thanks for all your help.
    I'll try to find a bucket of the 50w on Monday.
  8. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    duplicate post deleted
