I emailed Bridgestone and asked the following:
"Is there a difference in rolling resistance between a LP 22.5 and an 11R22.5 tire? And how does it affect fuel economy? Would the difference, if any, be measurable if just 8 or 10 tires were one size or the other? As in maybe just a tractor or trailer having the more fuel efficient tires.
If an 18 wheeler were equipped with all 11R22.5 vs LP22.5 tires, what would be the difference in fuel economy? "
And the answer:
"Generally speaking many LP22.5 tires have a slightly lower rolling resistance than their 11R22.5 counterpart, however, it is not true in all cases, and the difference is probably too small for the owner/driver to measure."
Regards,
Greg McDonald
Engineering Manager Corporate Accounts
Bridgestone America's Tire Operations
Interesting.
LP22.5 vs 11R22.5 and rolling resistance
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freightlinerbob, Nov 8, 2012.
The best way to find out is to go onto Michelins rolling resistance charts and look at just about every tire that is on the market and compare any brand's LP to 11R tire.
http://www.michelintruck.com/michelintruck/toolbox/toolbox-landing.jsp# -
That tool does not let you choose tire sizes, does it?
No. Michelins tire chart currently only shows the rolling resistance for the most popular size in that make.
This question will forever go without a definite result. I have changed from lp 22.5 to 11r 22.5 over 10 years ago. changed from all position to lug, to 3 different types of tread pattern. low pro may or may not have less r.r. 11r22.5 lowers the rpm at the same speed than the l.p. I always saw an improvement in m.p.g in a all position or steer tires when I put on my drives, compared to lugs, but the lugs lasted over 1, 1-1/2 years longer. take in consideration the amount of flats that occurred with the all position, were numerous compared to the lugs, which I may had 4 punctures since 08' & still going. the bottom line which for me is which tires over their life cost me more in the end? I still do not know. it is more longevity or better m.p.g. I think the response to the r.r. question was about right.
