Lowering RPM ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by carbass, Dec 12, 2010.
  1. carbass
    carbass Bobtail Member
    11
    Aug 25, 2010
    Hey guys, I need your help...
    When I am driving at 62mph, the RPM is 1600.
    I am want to lower rpm to 1450 at 62mph. I am thinking that it would be better for fuel mileage for light loads. How will RPM change if I change my tires to 11\22.5? Or the only thing I need to do is to change gears?
    Here's my info about the truck:
    Columbia , Detroit 12.7, 10sp
    Transmission FR-14210B
    Single Rear Axle Meritor RS-23-160
    Axle Ratio 3.07
    Tiers 295\75R22.5
    Grossing ~ 40000lb
  3. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    The main problem is 1450 is where a 12.7 looses all its power and falls flat on its face. You will change gears on every small hill you come to if you never get over 62 mph. The Detroit 60 series I have owned always got the best fuel mileage around 1600.
  4. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    going to 11/22.5 would only get you about 50 rpm differance. Going to a 11/24.5 would get you close to what you want. If you went to a 13 spd trans and run it a half gear down that would drop your rpms to below 1400 for 62. I have heard that can cause the trans to run hot though. High gear would put you about 1150 for 62 mph. I think I would look at other ways to try and save fuel. The pay backs on the above options would be a very long time. If they even made an improvement at all.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    and remember if you change tire and or wheel size, ya gotta adjust your ride height, or you will end up delivering a bridge!
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    would get you to height problems, and who pulls HiCube contaners cant solve this proble reajusting air ride valve!
    so all depends on what you tow.
    Yeah! and you loose more fuel shifting down on hills. There is no spliter in your tranny and shifting down to 9th you increase RPM too much!
    Not only DD60, but Mercedes PLD engines. Driving with lower engine speed is an illusion of fuel ecomomy.
    From my experience: newer Mercedes engines calculate value of fuel per revolution (g/rev) and at 1600 rpm this value is lower then at 1200. And curve is flat up to 1800 rpm, then engine is more powerfull but burns too much fuel.
    So I'm not sure you'll save fuel. Becouse with bigger tires to keep engine in optimal fuel efficiency you will drive faster and you'll get more drag (ore speed tickerts LOL).
    All modern trucks are designed for 50-60 MPH crusing speed. and engine runs with optimal RPM at this speed.
  7. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    That truck was geared like that for a reason. Thats where that engine is most efficent. A 10 direct and 3.07s is where most Schneider National trucks are at and Im pretty sure they watch their fuel milage very closely. The cost of changing is quiet pricey. The easiest way is to replace the whole center section in both rears. Fronts run about $3500 and fears $2500. It would take a long time to recoupe that money in fuel savings and the truck wont pull as good in the hills if you gear it higher.
  8. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Why can't you just change the crown and pinion gears only??
  9. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Sure... but shop labor would eat up any savings from buying a used or reman pumpkin...
  10. savage02
    savage02 Light Load Member
    163
    49
    Dec 21, 2007
    Upstate, NY
    What kind of milage are you getting now? Those look like pretty good specs seeing as how youve got a single axle with a direct drive tranny and the small 22.5's looks like its setup for economy as is.
  11. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    62 mph at 1600 rpm with a 3.07 ratio ?????????????????????
    Am I missing something about this ???????????
    You sure you don't have another gear you can shift into ????
    I don't know but it doesn't sound right unless you meant 4.07 ratio...... :biggrin_2554::biggrin_2554:
    Sumothertrucker Thanks this.
