Lowbed best brand made in western Canada
Discussion in 'Canadian Truckers Forum' started by MartinFromBC, Oct 25, 2018.
  1. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    Considering buying a new or lightly used, four axle lowbed, the last axle will be a booster. Considering Peerless, Knight, K-line, or another brand anyone can recommend. I wouldn't refuse to buy a trailer not made in Western Canada, but I do like buying locally made if the quality is there. Are the new trailers by these companies good quality? Having never owned a booster before, educate me on the good and bad of going to a fixed 3 axle with booster 4th axle lowbed. Will be hauling everything from little skid steers and backhoes, to dozers, loaders, excavators, processors, bunchers, and anything else. For lighter items maybe pulled by a tandem KW, for heavy loads a tri drive Mack, and yes the neck will be long enough to clear the tail frame of a tri drive I'll make sure of that.
    All input welcome, as well as suggestions on other brands.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Myself I like the Aspen stuff. Pulled a mechanical 3+3+2 set and just loved it. Was as light as you’re going to get a 75ton, and tough enough to drag out in the bush.
    MartinFromBC Thanks this.
  4. 3noses
    3noses Light Load Member
    155
    167
    Dec 16, 2009
    Clearwater, B.C.
    I had a K-Line I bought new from the factory in Langley in 1998 ,excellent trailer. Customer service was great, no complaints. Rep helped with custom specs and trailer always performed well. Built as R.T.A.C. legal tri axle 24' well but also with 2 position pin in neck to use a jump jeep, which I bought later.
    I would certainly buy another from my experience with K-Line.
  5. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    Aspen. Using tandem and tri drive get them to build with multiple king pin setting.
  6. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    Thanks very much for the input everyone!
  7. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    The Aspen neck is the best mechanical I’ve ever worked with. Really tolerant compared to some of the others as far as getting them apart and back together on uneven ground, and the modulars are real easy to wedge up in the back for ground clearance. I especially like the difference in cost to rig the truck. Pick-up ramps and a piece of 4”x4” 4 feet long are pretty cheap compared to a hydraulic system. Not to mention the difference in tare weight.
    MartinFromBC and Nothereoften Thank this.
  8. Nothereoften
    261
    265
    Oct 6, 2018
    And if crap goes wrong mechanical is still a lot simpler to fix. Worst case 4x4 falls out, you figure a way to lift it back up. Hydraulics stop you're screwed
  9. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    I want to say thank you again to everyone who was kind enough to post their comments.
