Low Voltage Disconnect Problems
Discussion in 'Kenworth Forum' started by TenGears, Jun 5, 2017.
  1. Frenchie80461
    Frenchie80461 Bobtail Member
    Jun 21, 2021
  3. Frenchie80461
    Jun 21, 2021
    Lid is located in the driver side kickoanel: left side, up 4. You're looking for bus relay type. There's one, then there's a plug-like deal, then ign. relay, then the Lvd. Sometimes they are not pushed all the way in, hence the " LVD bus is unpowered" warning. Make sure it's in good. If that doeirk, check your APU connectors to the truck batteries. Driver side step, remove to access the batteries, then look to your right, on the firewall you'll see 2 connectors, both having a + and- cables coming to it from batteries and going out to APU. make sure there's no corrosion. Also, remember that if you truck has needed a jump since your issue began, then there's a good possibility your truck batteries are not at full load capacity. Just saying....good luck driver.
  4. DavidK57918
    DavidK57918 Bobtail Member
    16
    Sep 27, 2021
    Did you find out what was the problem?
    I changed my batteries, all new, then, when I went to crank it, the dashboard would blackout.
  5. max954rr
    max954rr Bobtail Member
    11
    8
    Mar 29, 2022
    Same truck kw t680 2016 13sp with a isx15
    Hey I know it's been awhile since this but I'm going bonkers looking for the LVD I can't find it anywhere I found the mega fuse clean it and checked fuses there good change cables on batteries also to inverter too 2/0
    And the batteries are new deep cycle
    when I use my microwave my voltage drop slowly even with the Apu running until the invertor ( Jupiter 5000 watts) turns off.
    I'm thinking it's LVD , alternator 13.85 volts truck and the same for the Apu maybe a little higher .
    If someone can help would really appreciate this is making me go nuts
  6. max954rr
    11
    8
    Mar 29, 2022
    Hey I'm having the same issue did you find it LVD if you did can you let me know where!!! Thanks
  7. Hakotrucking1905
    Hakotrucking1905 Bobtail Member
    18
    Jul 1, 2021
    Hello
    I have changed my batteries it was good for week or two now I'm getting low voltage disconnect truck is running voltage showing 11.8 what causes to it any help appreciate
  8. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Check all components at the alternator level.
    Visual first. Then do a battery load test with a tech tool.
    ducnut Thanks this.
  9. Slim B
    Slim B Bobtail Member
    4
    Feb 12, 2023
    Will jumping the truck help the problem because mine won't start and I put new batteries in I habe disconnected them reconnected them to see and still got nothing and I checked the power everything is getting power anyone please let me know what else I can do or check
