Low Voltage Disconnect Problems
Discussion in 'Kenworth Forum' started by TenGears, Jun 5, 2017.
  1. TenGears
    TenGears Light Load Member
    82
    135
    Nov 7, 2016
    Ok, so I have a 2016 KW T680. Every other day after a full day run, I will get LVD alarms after 3 to 4 hours into my break. Not sure where to start looking for the problem. Any help would be appreciated!
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Check your battery connections and battery, on most LVD's they are usually set to go off when it senses that the battery voltage is falling below 12 volts.
    Even though your truck is not that old, you could also have a bad battery/batteries, or it could be a defective LVD.
    Check for loose corroded wiring, cables.
    Have the batteries tested.
  4. sepeda4
    sepeda4 Bobtail Member
    Jul 4, 2017
    I have the same problem can someone pleade tell me where the LVD is located on the Manuel it says on drivers side kick panel but I don't see it.
  5. train man
    train man Light Load Member
    53
    12
    Feb 14, 2017
    Anyone come up with a solution ?
    Newer batts (6mo old), run all day, city’s off in appx 4 hrs
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    A dealer can lower the LVD voltage settings or disable it completely.
    It is caused by dirty connections, bad batteries or too high of a current draw.
  7. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    I had the same problem.
    2016 T680
    Cleaned all the battery terminals and cables. Replaced two jumpers. Cleaned the LVD connections.
    Problem solved.
    Test all your batteries after the truck has been off for a couple hrs.
  8. Jersey 201
    Jersey 201 Bobtail Member
    Apr 24, 2020
  9. Jersey 201
    Apr 24, 2020
    I know this is old post but I have a 2013 t680 replaced the batteries but when turn the key nothing happens. Have power in the truck but nothing when i turn the key
  10. jlawall
    jlawall Light Load Member
    63
    15
    Jan 29, 2011
    wapwallopen pa
    I had same problem a while back and ran a ground wire from engine block to ground on starter, problem solved. This is regarding the no-start post. Completely agree with the low voltage connections fix.
