Low refrigerant pressure?
Discussion in 'Refrigerated Trucking Forum' started by Upright, Jul 10, 2015.
  1. Upright
    Upright Medium Load Member
    643
    461
    Jul 13, 2012
    California's Best City
    Got the unit to a shop and they only put 4lbs of r404a. Still throws the same code. Unit sounds like it wants to stall out while getting up to temp. This happens only when parked. Unit runs fine when underway. Any knowledgeable refrigeration guys here?
  3. FLATBED
    FLATBED Road Train Member
    What shape are the condenser and evaporator coil's in clean or clogged up ?
  4. Flyer
    Flyer Light Load Member
    183
    88
    Jan 20, 2008
    Coil is going bad. It's the one on top the steel header, behind passenger side door. $50 you can pry it up and pop new one, connect wiring harness. Job done.
  5. Johnny holt
    Johnny holt Bobtail Member
    19
    7
    Aug 4, 2015
    Try cleaning condenser on front of unit with pressure washer, bug, trash get in it makes it run hotter ! We do this everytime we come into the yard !
  6. RoadtoEmmaus
    RoadtoEmmaus Light Load Member
    100
    44
    Apr 20, 2014
    What was the solution?
