Low profile drop (Step Deck) 53ft trailers
Discussion in 'Flatbed Trucking Forum' started by superdutyfan, May 3, 2021.
  1. superdutyfan
    superdutyfan Light Load Member
    86
    76
    Mar 14, 2020
    So I would like everyone's opinion on the low profile step deck trailers I have herd they are more expensive for tires and brake / axel parts and wear out quicker due to the higher rpm of the 17.5 inch tire compared to the 22.5 inch ones.
    I am in the market for a 53ft step deck tandem axel sliding axles all aluminum .
    Thx
    PoleCrusher Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    I pulled one with the low pro. 17.5 on it and if you are loaded heavy going over 55 mph will make you want to put 8 spare tire racks on it to carry the tires you can blow out over a mo. of running over 55?
  4. rydr
    rydr Light Load Member
    123
    92
    Jan 8, 2019
    I've wondered about step decks with 19.5's they gotta be better than the 17.5's. I assume since some car haulers run 19.5's they should hold up pretty good?
    superdutyfan Thanks this.
  5. 50WT
    50WT Road Train Member
    2,030
    17,466
    Dec 26, 2015
    We have 3 trailers in the fleet that have 17.5 tires.
    One is a 53 ' step the other 2 are similar equipment trailers
    The summer heat is not your friend , when it's 75 degrees
    and up I'd recommend not over 60 mph. You'll go through brakes
    and keep an eye on wheel seals , those hubs get hot.
    One of our equipment trailers is around 39000 on the spread
    when loaded . If you can make enough extra money with the low
    trailer to offset maintenance it'll work out. If not I'd go with
    a standard stepdeck with 22.5 rubber. You'll need some high
    loads that pay well. Good luck and Happy Trails.
  6. 99kw900
    99kw900 Bobtail Member
    37
    186
    Feb 26, 2020
    My Wilson combo has a ride height of just under 39 inches with 22.5 rubber. Personally I'd never get a low pro unless I had a lot of loads for one and then I'd probably get a triple axel. But that just me.
  7. xsetra
    xsetra Road Train Member
    5,093
    6,939
    Aug 21, 2011
    I had a step with 17.5. Sliding rear axle.
    I wouldn't drive faster than 62 with temperature above 70. Tire wear was always an issue. Even after I replaced both axles and hardware. I rarely had any tires last a complete 8 months. Changed 1 or 2 each month.
    My step with 19.5 tires ,sliding axle, was an improvement. Still had tires not lasting as long as I expected. Lowered changes to 1 a month.
    My current step has 22.5 tires, fixed spread. When I bought it, I installed new tires. I had to replace 2 in 130,000 miles. Same miles and loads with all 3 trailers.
    I rotate my tires quarterly to extend life.
    With annual truck and trailer alignment.
    99kw900 Thanks this.
