Low power on brand new Kenworth t880?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Paverman, Apr 2, 2023.
  1. Paverman
    Paverman Bobtail Member
    5
    8
    Apr 2, 2023
    I purchased a new 2023 t880 tri axle dump truck with the x15/500 (productivity), allison 4500rds transmission and 4.30 rear. I live/work in SE Pennsylvania, so moderate hills. It has only 1400 mi. on it.
    My concern is, it seems underpowered or has a mechanical/programming issue?
    When loaded, my boost only goes to 28psi (I think I've seen it hit 30 once or twice), and always wants to stay in the 5th/6th gear range most of the time. I have to keep my foot to the floor and going up a moderate hill on a 4 lane hwy, can only get to 38 - 40 mph.
    This is the first higher hp truck I've owned, and the first auto...are my expectations wrong, or does something not sound right? BTW, no error codes or lights.
    Thanks.
  3. chupacabra
    chupacabra Bobtail Member
    24
    7
    Mar 11, 2014
    a friend bought a brand new truck 2020 T680 two months later the turbo failed with only 16,000 miles kenworth covered the warranty is a paccar engine, but they sit down in dealer for 2 months they had no parts!! Good luck!!!
    Rideandrepair and Bean Jr. Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    1400 miles?
    Might let her break in a bit more and see if the power improves.
    Rideandrepair Thanks this.
  5. Paverman
    5
    8
    Apr 2, 2023
    I thought about that as possibly being the issue, but for what I expected the power to feel like, it would have to have a considerable increase in power. I understand being new there would be a break-in period, but I just don't see it increasing that much.
    According to the shop mechanic at the dealership, it should have higher boost than the 28psi that it is putting out, that and the fact it wants to shift to higher gears, even as you start up an incline on the highway, leads him to think something isn't right.
  6. NH Guy
    NH Guy Medium Load Member
    610
    2,076
    Feb 26, 2023
    Did he plug it in? Could be some messed up settings from the factory.
  7. Paverman
    5
    8
    Apr 2, 2023
    I have an appointment for this Tuesday, they're going to plug it in and pull data logs as well as check all the settings and hp output readings. I'm taking it to them fully loaded so they can also test drive it, to see how poorly it performs when climbing hills. Hopefully they'll be able to figure it out, and that it's just a minor glitch or setting that wasn't right.
    I joined this forum in hopes of getting insight from others, in case the dealership can't find a problem, not to mention just to learn more about these larger trucks and motors from people with much more experience than myself!
    Rideandrepair and OLDSKOOLERnWV Thank this.
  8. AModelCat
    154,238
    Put it on the dyno. That'll tell you what its really laying down. If its healthy you'd probably get around 400-420 hp to the ground.
    Rideandrepair and Paverman Thank this.
  9. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    500 in a triaxle with 4.30 gears I’ll assume 11R24.5 rubber should do well. What’s your gross like 80K ?
    guess is something in the computer is set on economy….
  10. Paverman
    5
    8
    Apr 2, 2023
    Yes, 11-24.5's...Gross is 80k, but here in PA I'm only allowed 73,280 (truck plus 23 1/4 ton load).
    Yes! It's exactly what I would expect a truck that is set to "economy" would feel like...when I started climbing (loaded) a moderate (6%) 1/4mile long incline on a 4 lane highway the truck bogged down to like 25 - 30mph before it wanted to downshift from 5th gear to just 4th, with my foot to the floor on this straight and steady incline, the best it could do was 38mph by the time I reached the top. Maybe I'm wrong, but that just doesn't seem right to me...?
  11. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    If productivity is new name for efficiency your issue will be in the programming . They accelerate slow when empty and like low rpm even when it costs you a lot of road speed . Plus engine holds back power until a certain mileage is hit . My old company had two of them and both gained power around 50,000 miles but are still slow picking up speed but now hold it better once going .
